  • SN95 4.6L Mustang Tech
C&L Upper Intake Plenum??
  • Thread starter Thread starter 03MGT
  • Start date Start date Jun 2, 2005
03MGT
199
  • Jun 2, 2005
Will the stock T-body fit on the C&L Intake Plenum??? Im having to much trouble with the 75mm tb and I want to throw the stock one back on and keep the Plenum on.
98blackmagic
386
wouldnt you like to know
Jun 2, 2005
  • Jun 2, 2005
yes the stock tb will work, when I ran mine on the dyno last month we changed tb from my 75 back to stock just to see if there was any power change. The 75 was worth 2 hp, so we stuck with it. What problem are you haveing with your tb?
03MGT
199
  • Jun 2, 2005
The TB is screwing up my idle and the rpms goo down slow and like to stick at 1500... Also I hate how When the tb closes it sticks a lil but wich messes up the smooth pedal feel of the stock tb..
98blackmagic
386
Jun 2, 2005
  • Jun 2, 2005
well on mine the 75 tb was only worth 2hp and I have a 98 with the PI intake, c&l elbow, bbk cold air, 80mm massair, and of course my tb so if you are not happy with the big one I guess you would not be giveing up more than a few ponies to go back to stock, good luck
starchman
73
Sheridan, AR
Jun 2, 2005
  • Jun 2, 2005
Did you re-use your TPS, or get a new one? Did you need to re-calibrate the TPS?
03MGT
199
  • Jun 2, 2005
I reused the stock TPS.
starchman
73
Sheridan, AR
Jun 2, 2005
  • Jun 2, 2005
The issues your having sound more like calibration issues to me; the TB is not likely to be at fault. Have someone press the gas pedal while you watch the TB; make sure it opens and closes smoothly. Did you make sure it was fully closed (using the set screw) before you installed it? Sorry if I'm being picky, but if you replace the TB and it turns out that it's your TPS, you just wasted time/HP for nothing, and you will still need to calibrate the TPS. I don't suppose you have or know someone with a Predator?
GDawg
1,469
Nevada
Jun 3, 2005
  • Jun 3, 2005
What brand? I bought a MAC 75mm and it did that exact same thing. I took it back off after a week and put on an Accufab 75mm. The Accufab is smooth as butter and idles perfectly. Screw MAC's throttle bodies. I won't even resale it cause it's such crap. (btw, I have a C&L plenum too and I love it)
SilverGTV8
295
West Brookfield, MA
Jun 3, 2005
  • Jun 3, 2005
It's called throttle hang it's caused by the IAC,
There are several posts about how to fix it.
The cheapest and easiest way is to take a1/2" copper pipe cap, drill a 1/4" hole and insert it in the IAC line. This will help drop the rpms down to about a 1000 much quicker.
Throttle hang is a common problem with TB and plenum swaps and can be solved.
Red35th
609
Houston, TX
Jun 3, 2005
#10
  • Jun 3, 2005
  • #10
It could also be the throttle stop screw on the TB. It's a little screw at the back left that dictates how much/little the butterfly stays open when you get completely off the gas. If the screw is holding the TB open too far then it can cause an excessivly hight idle. Just a thought.
SilverGTV8
295
West Brookfield, MA
Jun 3, 2005
#11
  • Jun 3, 2005
  • #11
Ahhh sounds like a MAC TB. I know they had issues with the way the butterfly interacted with the TB sides. I would contact MAc and see what they want you to do.
i believe they would suggest find where it is hanging and sand the butter fly so it doesn't.
Makes me happier and happier, that I purchased an Accufab TB, instead of the BBK or Mac stuff.
C
closer9
77
NW AR
Jun 3, 2005
#12
  • Jun 3, 2005
  • #12
GDawg said:
I won't even resale it cause it's such crap. QUOTE]
Would you give it away? I'd like to mess around with one...
NYStang2002
231
Wappingers Falls, New York
Jun 3, 2005
#13
  • Jun 3, 2005
  • #13
Are ford racing throttle bodies any good? I was looking into getting a plenum/throttle body combo and think accufab is too pricey. I definately wont go the MAC route because of their reputation for making low quality junk parts. I'll go the accufab route if it's definately the best. I just wanna know if anyone had any good/or bad things to say on Ford racing throttle bodies.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jun 3, 2005
#14
  • Jun 3, 2005
  • #14
Just got done installing C&L upper intake plenum. Must say, i can't wait to drive to see if I can fewel any difference...
RedBullitt
462
Morgantown WV
Jun 4, 2005
#15
  • Jun 4, 2005
  • #15
check out the dragon, they had some good dyno numbers i have read, although i have not had any personal experience with them. anyone tried one?
starchman
73
Sheridan, AR
Jun 4, 2005
#16
  • Jun 4, 2005
  • #16
I installed the Dragon plenum/TB (75mm) on my brother's 03GT; it was very nice. We also put on the full-length CAI from Demolet (Tuneable Induction) at the same time; no dyno test, but nice SOTP gain. I'm selling them in the trader's section (my brother wrecked his car) if anyone's interested.
GDawg
1,469
Nevada
Jun 4, 2005
#17
  • Jun 4, 2005
  • #17
Someone's already offered me some money for it, sorry.
03MGT
199
#18
  • Jun 4, 2005
  • #18
I just put the stock tb on, the cars idle problems are gone!!! Ill sell the MAC 75mm TB for 60 bucks if anyone want it.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
