C4 fluid leak
  • Thread starter Thread starter zigmont
  • Start date Start date Oct 11, 2009
Z
zigmont
81
  • Oct 11, 2009
My 64 1/2 convertable has a fluid leak that is coming out around the transmission gear selector shaft. It seems that after you shut off the engine the fluid drains back out of the converter into the transmission. This raises the fluid level above the selector shaft, and that is when it starts to leak. No leaks while engine is running.
Is there a way to correct this problem without pulling the transmission? If I have to pull the transmission, what will it take to fix the leak?
I'm thinking that this may be a typical issue with C4's. Yes???
brh66cobra
35
  • Oct 12, 2009
Yes it can be repaired without removeing the trans but you will need to remove the pan and valvebody. There's a nut that attaches the selector shaft to the detent bracket that has to be removed and the kick down lever. After that its remove and install seal. Be sure to install a new oring around the kick down shaft too.
Z
zigmont
81
  • Oct 15, 2009
C4 transmission leak
Thanks for the help
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
