C4 Help
  • Thread starter Thread starter Jester67
  • Start date Start date Oct 5, 2004
Jester67
908
TN
Oct 5, 2004
  • Oct 5, 2004
Could someone please help? I am trying to identify the transmission in my car I know it is a C4 but I don’t know what year. Can this be accomplished with the transmission in the car? Where is the best place to look to get the casting numbers and a decoder for these numbers? I have found these numbers on a plate on the side and C6AF-TD027-C and another on the tail shaft is C6027A01”or 4”C. I want to put a shift kit in it and need to know which one I have.
J
JB66
565
New York
Oct 5, 2004
  • Oct 5, 2004
Looks like a 66 by the 'C' = 1960's & '6' = digit of current year production. However, they were in everything from full size to Econolines. No tag on the low-reverse servo cover bolt? Anyone else?
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Oct 5, 2004
  • Oct 5, 2004
The numbers you gave are PART numbers of the part, like 7a01c, it should read 7a039 this is the part number of all C4 and C6 tail shafts.
You need to look for a metal tag bolted to the drivers side servo for the correct number. there are a few different models like the small 24 spine input shaft and the larger 26 spine. there is also different valve bodies for each year. The number your looking for starts with a "P". An example would be a 65 mustang with a 289 would be PCW-H or PCW-J
Jester67
908
TN
Oct 6, 2004
  • Oct 6, 2004
Well I checked and just my luck no tag. Any other ideas?
J
JB66
565
New York
Oct 6, 2004
  • Oct 6, 2004
The diameter of the torque converter will narrow it down some.
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
