C4 shift points?
  • Thread starter Thread starter Dugan
  • Start date Start date Jan 13, 2008
Dugan
47
Portage Mi
Jan 13, 2008
  • Jan 13, 2008
What should a C4 shift at? I am asking because mine seems to shift rather low, usually 3000 RPM's or lower. Is this right?
enferno
418
  • Jan 13, 2008
just cursing around, i set mine to shift between 1800 and 2000 rpm.
at WOT, it should shift a lot higher than that though
Dugan
47
Portage Mi
Jan 13, 2008
  • Jan 13, 2008
hmmm. when i take mine out of storage after winter i will have to see, don't think i ever looked at the tach at WOT.
jcp123
408
Tyler, TX
Jan 13, 2008
  • Jan 13, 2008
I've seen it shift as low as ~1100rpm on my '68. Normal driving for me, it'll shift at 1400-1600, and on medium-hard driving anywhere from 1800-2500. Rarely does it ever even get to 3000. WOT shift point for a stock setup is 4400.
351vic
33
Pierz, MN
Jan 23, 2008
  • Jan 23, 2008
Mine will shift at idle. It's in third before i get to the end of my driveway if it's warm but on WOT it typically runs to about 4700 before it shifts i think
enferno
418
  • Jan 23, 2008
sure it's not in second?
some early c4's start off in second for better traction, then shift normally from there
Cobain03
996
Lexington, Ky
Jan 23, 2008
  • Jan 23, 2008
mine shifted at around 4300 under WOT
now it shifts whereever i want it to
Fast63
717
  • Jan 24, 2008
mine shifts at about 6000 in "D" at WOT but it was modified some by the previous owner so I have no idea what has been done to it.
351vic
33
Pierz, MN
Jan 25, 2008
  • Jan 25, 2008
Yes sir I'm positive. I can see it on the tach and feel it. It's VERY minute but if I'm nice to it outta the driveway i can wind it up to highway speed and it never shifts again lol
Dugan
47
Portage Mi
Jan 26, 2008
#10
  • Jan 26, 2008
  • #10
Ok. Another question, can the gears in the rear end affect when it shifts?
Sorry I am still new to this, as it is my first classic car, well and my first ever car.
N
neverhit
#11
  • Jan 26, 2008
  • #11
On the back of my 69 C4 is a vacuum modulator which is cylindrical in shape. From the modulator is rubber tube that goes to a steel tube and runs toward the engine. At about the firewall it switches back to a rubber tube that goes to the vacuum on the intake manifold. The vacuum causes the modulator valve to shift. A light pull on the rubber hose that goes to the modulator on the back of the tranny will reveal a small screwdriver slot. I turned mine a couple of turns in and it increased my shift point under hard throttle. Under light throttle, it shift at low speed still. I put a vacuum pump at the intake manifold end and verified it was holding a vacuum. I saw on another forum that you shouldn't go much past two turns as it may cause damage, but I can't confirm (Maybe someone else can..). For my 69 with the cross member to support the tranny, I needed a long flat blade screw drive and started the screw driver behind teh tranny support and guided it straigh into the modulator. Hope that helps.
Dugan
47
Portage Mi
Jan 27, 2008
#12
  • Jan 27, 2008
  • #12
which way do you turn it to increase shift points, clockwise or counter clockwise
N
neverhit
#13
  • Jan 28, 2008
  • #13
I turned it clockwise.
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
R
AOD HELP! Runs fine in (D), long 1-2 shift in D
  • rwordenjr
  • Sep 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
rwordenjr
R
