  • 1994 - 1995 Specific Tech
CAI question about filter size?
  • Thread starter Thread starter johnny_munyak
  • Start date Start date Apr 8, 2009
J
johnny_munyak
97
  • Apr 8, 2009
picked up the American Muscle CAI for my 95 GT. Lets just say I'm not that impressed......but for the money, it will have to do. Didn't want to shell out big money for a mediocre mod.
First off, I had to purchase a couple of larger hose clamps because the ones in the kit were too small. Secondly, the bracker that holds the filter through the fenderwell....the mounts that fit into the stock rubber grommets......the holes that were drilled were nowhere close. I did manage to get one of them secured along with the rubber grommet and bolt that bolts it to the side of the fender at the top. Annoyances yes....but I did get it to fit half assed.
My bigger concern comes from the size of the filter they include with the kit. It is not very big? Not sure if it has to be, since they say it has more surface area to pull air in from, but I was expecting a little bit more. The filter is approximately 6-7" long and about 5" in diameter then tapering down smaller. (conical)
Will this thing flow enough air with that little filter? ....my car will also be getting a H/C/I swap in the next week or two......
TrueBlue95GT
966
Connecticut
Apr 10, 2009
  • Apr 10, 2009
It doesn't really matter....
Stopsign32v
394
Gville, SC
Apr 10, 2009
  • Apr 10, 2009
Bigger the better
TrueBlue95GT
966
Connecticut
Apr 11, 2009
  • Apr 11, 2009
It's an equivalent topic to exhaust diameter....
ProKiller
3,064
15
78
PA
Apr 11, 2009
  • Apr 11, 2009
like everything else, you get what you pay for. did you make sure you had the right clamps in the right places? the filter should be okay
Stopsign32v
394
Gville, SC
Apr 11, 2009
  • Apr 11, 2009
No its not
TrueBlue95GT
966
Connecticut
Apr 12, 2009
  • Apr 12, 2009
Stopsign32v said:
No its not
Yes, it is. There is a minimum surface area needed and then anything bigger does nothing. A typical 5" diameter 6" tall air filter is plenty for a 302 that peaks in power at 6000rpms....
Stopsign32v
394
Gville, SC
Apr 12, 2009
  • Apr 12, 2009
If the exhaust is too big it will actually hurt your performance, a bigger air filter will NEVER EVER hurt performance. You are wrong sir.
TrueBlue95GT
966
Connecticut
Apr 12, 2009
  • Apr 12, 2009
However, bigger is not necessarily better. Back to the original topic. The filter should suffice...
Stopsign32v
394
Gville, SC
Apr 13, 2009
#10
  • Apr 13, 2009
  • #10
If it will not hurt then why would you not have as big as possible? Look at JLT's intake, they are all 4" piping. I have 4" piping on my 5.0 and a 9" long filter. The throttle body is the same way. Take in example your setup, while I'm sure you make decent power you would be better off with a 90mm TB. Even if it did not make more power it certainly will not hurt it. Go big or go home.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 13, 2009
#11
  • Apr 13, 2009
  • #11
you can probably replace it with a longer k&n one... but a larger one may not fit in the fender
TrueBlue95GT
966
Connecticut
Apr 13, 2009
#12
  • Apr 13, 2009
  • #12
HAHAHA...so why doesn't everybody just put a spyder efi intake manifold on their car with a Accufab 105mm? You can go ahead and do that to your own car if you would like, but most people like to keep the power in a broad powerband. I don't want to be driving a civic where if I want power I have to reach 6000RPMs. Bigger is not always better...and you will lose "power" in the lower RPMs.
Stopsign32v
394
Gville, SC
Apr 13, 2009
#13
  • Apr 13, 2009
  • #13
Now you are talking about intake manifolds. Where did I say anything about them? I bet your 347 doesn't make much past 410rwhp does it?
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
  • mnky99
  • Sep 5, 2025
mnky99
M
