Black95GTS
Yeah, I guess it kind of makes sense that it cannot supply enough fuel under the most stressful conditions.
If Adam doesn't hear his name being called, I'll probably start a new thread in a couple of days.
Thanks
Humm I'm trying to recall this. I do remember one thing about GT's vs. Cobras. The Cobra's MAF curve calls for a fatter A/F then the GT's at WOT, which is why you hear a lot of GT owner's complaining about pinging at WOT and not so much from the Cobra side.
It's a classic case of two known problems:
1 - Dirty MAF (it gets dirty over time, especially with an oil based conical aftermarket filter) which is not reporting all of the air entering the engine, thus causing a lean condition. At WOT, the only information your computer uses in terms of air is from the MAF.
2 - An already "lean" MAF transfer function
There are a couple different fixes... adding an FPR would fix the symptom but not the disease. Clean your maf and air filter, it just might be that easy.
Adam
