Brakes Caliper Piston On The Rear Won't Go Back In
Andrew Dowell
I have a 2002 mustang gt and the rear caliper pistons won't screw back in. I don't know if I need to go rent the tool, or my e break is still on (but the lever is all the way down) or if I just need new rear calipers. please help thank you
In my experience IF the rear caliper piston won't turn then the caliper is toast (assuming that the brake bleed screw is open). I JUST replaced one of my rear for the same reason. You could tell the piston was binding because the rotor was polished on the inside but not on the outside (brakes dragging).
