Calipers are driving me NUTS
KTP Dave
74
I have an '04 Cobra and I am trying.....key word is trying.....to change my pads and rotors. I have been trying for the last 2 hours to get the pads back in but I can't figure out how because the caliper is 2 pieces. I have never changed brakes on a piece caliper like these and I can't get them to fit just right. SOmething always comes loose or falls out. Does anyone know where I can look? Or what the process is before I throw this rotor through the windshield?
Thanks!!!
You only have to take off the caliper, not the bracket the pads sit in. There are two pins with e-clips on them. Take these off and the caliper lifts off exposing the pads that are held in the bracket. The pads simply slide out with the little holding clips on each side of the pad. It's really not a big job.
To get the bracket out of the way for a rotor change, remove the bracket that is held on with two bolts in back, without the pads in it.
Hint - Do only ONE side at a time. That way, you always have the other side for reference if you forget how things go back together.
When you say things keep falling out, I just cannot figure out what would be doing that.
Put the bracket back on, slide the pads in, drop the caliper on with the pins and e-clips.
The backs are a little more difficult but the fronts should be pretty easy.
