calling AOD experts
  • Thread starter Thread starter 352Ford2
  • Start date Start date Jul 17, 2006
352Ford2
393
Seattle,WA
Jul 17, 2006
  • Jul 17, 2006
Having issue with fluid level. The dipstick shows way high cold and way low hot. According to ford shop manual that is a symptom of front pump, front pump bushing, or the servo by the front pump.
Any other ideas what it is and how bad is it to drive it? Is it killing the trans and should be replace immediately or can drive it as long as it still works?
The Shape
2,224
East ARKANSAS Delta
Jul 17, 2006
  • Jul 17, 2006
Is it showing any other symptoms??
352Ford2
393
Seattle,WA
Jul 17, 2006
  • Jul 17, 2006
no, but it does have a leak and I am worried if it keeps getting worse I will not be able to add fluid becasue the non running level is so high
Jaswir
578
Orlando, FL
Jul 17, 2006
  • Jul 17, 2006
its going to show high when its cold... thats why you run your car untill warm and then check it while running, if its still low add fluid... if its showing low when warm im sure there isnt just enough fluid...
352Ford2
393
Seattle,WA
Jul 17, 2006
  • Jul 17, 2006
it should show low when it is cold not high, thermal expantion and all
RYC CUKR
1,437
Orlando
Jul 17, 2006
  • Jul 17, 2006
Not sure of the cause and how bad it can be but you might want to post it over at www.clickclickracing.com. They have an AOD/C4 forum and there are some pretty knowledgable guys in there.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
