7upstang91
Coming from a guy who has two!.
Does the on3 not come with a BOV, or am I just missing it?Actually wouldn't pass up On3. At least from the coyote perspective, they are quite impressive. The quality has come quite along ways.
Joe
The only thing it doesn’t come with is the mass air and y pipe....from what I have seen. I guess one question to ask is if you went with On3, what is the cheapest place to buy?Does the on3 not come with a BOV, or am I just missing it?
Joe
FWIW I have seen the CX racing kits come up pretty frequently on local CL and really cheap too, like 750-800. No personal experience but I know other guys who have had fitment issues. The on3 kit seems to have improved quality and they have everything you need plus upgrade options. The most fun car Ive been in was on3 powered notch. Stock block and cam, built AOD, 3.27 gears, just silly.
Maf is must(unless you put it in a 5" pipe or run twins with 1 maf)!
what makes you think a MAF is a must??
That's great feedback, thanks!I bought the On3 kit back in December and installed it when swapping out my old stock motor for a 306 FR crate. I don't have many miles on the car yet as I'm still finishing up the tune and a few other things but can give you my thoughts on the kit so far.
I'm quite happy with the hot and cold side parts. They fit well and the only spot I had a bit of trouble was getting the crossover tube to mate up between the headers but the flex joint they use makes that pretty easy if you have a buddy to help. I had my hot side ceramic coated to not have to worry about wrapping anything. The downpipe and turbo blanket On3 sells is definitely worth it IMO and does a good job keeping heat away from the other nearby parts.
The hot side v-band clamps they give you are absolute junk and will fail the first time you remove them. I ordered ones from Racepart Solutions for all of the hot side connections and they work 100x better. I took others' advice and didn't use the manual boost controller they provide and instead use an electronic solenoid that I can control from my PiMPxs (MS3 ECU).
I'm also looking at waste gates from a better brand as well since the On3 ones are notoriously bad quality and not something you want to fail.
As far as spark plugs, while it's a moderate pain to do the passenger side, I've done it 3 times now by myself and it only requires removing the elbow going to the throttle body and then unbolting the downpipe from the turbo and the rest of the exhaust and tilting up and out of the way. I don't bother removing it completely since I can keep my wideband sensor installed in this way and it makes it easier to get back into place again.
I took pictures pretty much every step of the way during the install so if you have any specific questions or want to see how anything fits/looks just let me know and I'd be happy to share. All that being said, when you feel that boost kick in for the first time it makes all the work so freakin worth it!![]()
the stock maf is only good for around 900 kg/hr. the more are you flow The more voltage the sensor sends back. But, it only goes up to 5v. So your computer and injectors don't know the difference between 900 or say 1400
