Cam Bearings
  • Thread starter Thread starter Red66GT
  • Start date Start date Jul 16, 2004
R
Red66GT
214
Simi Valley, CA
Jul 16, 2004
  • Jul 16, 2004
Anyone know if it's important to change the cam bearings when changing the cam?
If so, how easy, or difficult is it to change them?
ashford
485
fargo ND
Jul 16, 2004
  • Jul 16, 2004
if they arent damaged or worn out you can reuse them.
to replace them lets just say they are the first thing to go into an engine during assembly
6Stang7
1,470
Livermore, CA
Jul 16, 2004
  • Jul 16, 2004
What ashford means, is that they are very hard to replace. Cam bearings are made out of a soft metal, and are VERY easy to dents and ding. Not only does it require a speical tool (and a speical touch) to remove and install them, but if you do dent or ding one, then you risk causing some serious damage to the motor. How long have they been in there?
R
Red66GT
214
Simi Valley, CA
Jul 16, 2004
  • Jul 16, 2004
Been in for about 50,000 miles, give or take a couple thousand.
What tool would need to be used exaclty, and where can I find it if I have to?
Hack
1,945
Minneapolis
Jul 17, 2004
  • Jul 17, 2004
The books that I've read say that cam bearings almost never wear out. They certainly shouldn't be worn out after 50,000 miles.
If they've been damaged during camshaft removal/installation, take the engine to a pro for replacement.
edit: since you asked, for removal you need a special mandrel that fits the bearing ID, shoulders against the bearing shell and clears the bearing bore in the block. You'll also need a long bar to reach inside the block.
For installation: the bearings are pressed in. They must be pressed in squarely! Then they may need to be trued (there are various methods to do this, probably a boring bar is preferred). You can also blue and scrape the bearings. The books I've read say that it's a really bad idea to do this yourself.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Ignition Question
  • WantAn88GT
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
WantAn88GT
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
