Cam choice help
Scottybronco
41
Bc
Looking for some advice
It's 306
Holly terminator x
Trickflow track heat intake
76mm throttle buddy
Xe268h cam
30lb injectors
Pw heads 175cc 61cc 2.02 1.60 7/16 stud
It's a standard vehicle
Question is I'm looking to get some more Na power out of it and looking to go a bigger camshaft... to try and do this the engine is already out I was thinking aboutna x303..
Car is a summer cruiser not a daily
Any input would be appriciated
What are you trying to do with the car (track, street race, cruise down to DQ)? What are your power goals?
It's a toy take it work sometimes gunna hit the track aswell but it will mostly be on the street,no idea what power it might even make.. I know I just want more ide like to keep my power brakes working properly not super concerned with anything else what other issue might I run into ?
Do you have a roller cam or non roller? The XE268H is non roller, X303 is roller.
Has the car been tuned properly, given a stand alone ECU?
I use the xe282hr in my turbo 331 car. The vacuum is so low at idle I had to add a vacuum pump for the brake booster. I can't speak on power since I'm turbo but it is a decent camshaft for my set up and what I'm happy with.
Contact these folks and you won't be disappointed. Understand that they stay super busy but do exactly what they say.
