Well as you all know, I snatched the motor out of my car to inspect what I thought was some major damage. Turns out that I had a couple of bad lifters. While the engine has been out, I thought it would be a good idea to do a minor rebuild/repaint of the bottom end. Everything is pretty much put together but I have a dilemma. I have two TF cams, one stage one and one stage two. I'm really not set on using either one and also have thought of going custom but then I'd still have two cams sitting around. The motor is a 306 with AFR 165 heads and a V3 that will be sitting off the side of it. What should you guys thing I do?
They ASSURED me that they'd taken them all down before the internet happened.
