  • 1994 - 1995 Specific Tech
Cam Decisions
  • Thread starter Thread starter MacTwpStangs
  • Start date Start date May 10, 2007
M
MacTwpStangs
  • May 10, 2007
I'm going to do a cam real soon here and I need some advice. I Have a 94 AODE with Shortie headers, non-catted header back 2 1/2". CAI, Pulleys, 70mm Throttle Body, and thats it. I'm also gonna do a Pete Jackson Gear Driven Timing replacement at the time of Cam. I JUST NEED SOME ADVICE ON WHAT OTHERS HAVE DONE. I'm not totally positive about lift ratios and whatever else. Thanks
parchisi
519
New Mexico
May 10, 2007
  • May 10, 2007
I say keep saving your money 'till you can get a complete HCI setup, that way the camshaft will be doing the most good. Otherwise, the Steeda 19 cam was designed for our ECU's so you could get away with running that with the least hassle.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 10, 2007
  • May 10, 2007
A cam can be a nightmare with an AODE if you plan to keep it stock.
In a nutshell .......
You stand a chance of a very soft or even dead low end
Be sure to focus your research on those folk with auto persuasions
and
Get their input for how things turned out with their combo
I also would advise you to do heads and intake with the cam install
Now ... About that cam drive
I've heard they make a good bit of noise
NO ... CHECK THAT
I've heard they make a L O T of noise
Grady
True 5.0
237
Southeastern Wisconsin
May 10, 2007
  • May 10, 2007
NO ... CHECK THAT
Grady
Yes. I put one on a number of years ago and took it off after a short time. I couldn't take the noise any more. Went back to double roller chain.
BTW - You will have to machine the oil dripper off of the back of the front engine cover to use the gears.
BTW2 - I'll sell you my gear set if you're interested. They're like new.
D
DaveB
637
Middlesex and Pomona, NJ
May 10, 2007
  • May 10, 2007
Work on the transmission first. Shift Kit, bigger pan, cooler, and a high stall speed converter along with some gears. 3.73s or 4.10s.
M
MacTwpStangs
  • May 11, 2007
I planned on that also I know a shift kit and gears, but need to read up on the Converter a lil. Thanks though. I know I need to work on the trans before the cam. I live in MI so most of my work will be done in the winter. I just am planning ahead so I buy the parts now instead of spending money on other useless ****. I also do plan on doing the intake at time of cam. Just not posiotive on what on,,, thinkin Edlebrock Perf. ...heads I can't afford currently so thats that. And how loud are the quiet gear drives??? I know the loud ones whine a lot but never heard the quiet one???
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Lost low end torque
  • JJ's90fox
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2025
Methodical
Progress Thread Heads/cam decision
  • RileyDymond
  • Oct 26, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2024
rednotch
