what is the best cam for a daily driver?? I want reliabilty foremost before power and sound and all that...reliability is the most important thing to me...it will be matched to some ported gt40 iron heads (not p)...
nmcgrawj said:I got a question....
When working with the exact same combo, can you have a cam that idles like stock and make as much power as a cam that has a really lopey idle? I guess my big question is how does the idle quality affect power output?
Im just wondering for my combo with ported twisted wedge heads, tfs r intake, long tube headers, on a 357(351 bored .030 over).
nmcgrawj said:ok i think i follow you...i just didnt know if the cam designer had more "freedom" for the cam design, if you could get away with more power in the upper rpms with a rougher or not as stable idle. I guess kinda like if you run an LSA of 114 compared to 107 or something![]()
The only way around that AFAIK is to force the EEC into open loop at idle. The EEC is seeing a false lean condition from all the unburnt charges and richens the mixture. And then it surges. Then it stalls.final5-0 said:I can idle down to as low as 750 rpm's and it'll really lope but over time the pcm will use its adaptive strategy to make things become more unstable during idle conditions![]()
Rootus said:The only way around that AFAIK is to force the EEC into open loop at idle. The EEC is seeing a false lean condition from all the unburnt charges and richens the mixture. And then it surges. Then it stalls.
But you already knew that... I just like to hear myself talk I guess...
Dave
one other thing What kinda of LSA's do you guys have with your Ed cams? Do they lope pretty hard at idle or do they run on the smoother side??
idle
as Ed will be grinding the cam for my 351.
Dave
I hate to say it, but at that time, I was too stubborn to admit I could not do it my way nmcgrawj said:ok i think i follow you...i just didnt know if the cam designer had more "freedom" for the cam design, if you could get away with more power in the upper rpms with a rougher or not as stable idle. I guess kinda like if you run an LSA of 114 compared to 107 or something![]()
302fordracer said:man my thread got jacked...
