Cam Gears
If I understand the question correctly, the answer is Yes. If the motor has the Windsor PI Cams, they have pressed on cam gears, which cannot be removed from the cam. You cannot order these cam gears separate either so you have to use the Romeo Cam gears or aftermarket ones.
