  • SN95 4.6L Mustang Tech
Cam help!!!
  • Thread starter Thread starter LS2 KLR
  • Start date Start date Feb 21, 2004
1 of 2 Next Last
LS2 KLR
452
Houston, TX
Feb 21, 2004
  • Feb 21, 2004
I have 350 miles on my new motor and already want to get more aggressive cams! They sound great but I made the mistake of telling the guy over the phone I wasn't changing my springs. I ended up doing it anyway and think I should get something more aggressive.
I currently have:
2730 Street Performance, Mild race. Duration @ .050 230/230 Lift .500/.500 LSA 114. . 3.27-3.73 gears. Direct replacement for 92-98 SOHC. RPM range 1500-6000 with no valvetrain modifications.
I plan on getting these installed next saturday:
2760 Hot Street/Strip N/A Camshaft. Duration @ .050 242/232 Lift .550/.550 LSA 113. 3.27-4.10 gears, 2000+ stall converter, rough idle. RPM Range 2000-6500. Needs exhaust, intake. PI head.
Eventually I will be increasing my shot as well to more like 150-175. I'm open to ideas!
hognutz
1,940
albany, oregon
Feb 21, 2004
  • Feb 21, 2004
If you are keeping your stock heads I would get the VT wild or stage II cams. they seem to do better on a stock head. more lift less duration than the 2760's. seen some dyno data on them that made my head spin. 29hp on a stock gt. have never seen the 2760's pick up that much on a stock car.
NasaGT
1,993
Virginia
Feb 21, 2004
  • Feb 21, 2004
hognutz - I've seen a couple VT cam dynos, and it seems like that 29 hp was strictly from the install of the new cams, and no tune right?
hognutz
1,940
albany, oregon
Feb 21, 2004
  • Feb 21, 2004
no it was tuned at t&j. still 29hp from a cam and a tune would make me not beat my wife for a whole day I would be so happy. ha ha
hognutz
1,940
albany, oregon
Feb 21, 2004
  • Feb 21, 2004
the thing I really liked about that is the vt wilds sound just sick. so if they don't hurt the performace it made my mind up.
nickthegenius
1,631
Elwood, IN
Feb 21, 2004
  • Feb 21, 2004
hognutzYou should show that post to your wife. Maybe she'll buy you a pair of cams for your anniversary or something LOL.
On topic, though I would almost have to push the VT Stage II's also even though I have a set of Comps myself. I've almost thought about trying to sell them to get a set of VT Stage II's since they haven't been installed yet.
hognutz
1,940
albany, oregon
Feb 22, 2004
  • Feb 22, 2004
I bought her boobs this year so she owns me the cams.
LS2 KLR
452
Houston, TX
Feb 22, 2004
  • Feb 22, 2004
Could someone link me to their site so I could make a purchase
Redfire03GT
395
Newark, CA.
Feb 22, 2004
  • Feb 22, 2004
VT wild N/A cams won't pass smog though, will they?
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Feb 22, 2004
#10
  • Feb 22, 2004
  • #10
I have Comp cams stage II and am getting 280 rwhp with just a longtube back exaust, C&L and tune
Sam98
1,625
Albuquerque, NM
Feb 22, 2004
#11
  • Feb 22, 2004
  • #11
There is a reason that cam manufacturers list engine requirements for their various cams, namely the cams are designed to work with specific setups. If you ignore those recommendations, the results will be at best disappointing and at worst catastrophic. Too much lift can cause a valve spring to break and result in a valve dropping into the cylinder and punching a hole in the piston or block. A mismatch of engine components can result in your engine having less power than stock. The best thing to do is discuss your goals with the manufacturer, and follow their recommendations.
mogs01gt
3,113
30
119
Ohio
Feb 22, 2004
#12
  • Feb 22, 2004
  • #12
With Nitrous I would think you would need a split duration cam with more duration on the exhaust side. Also, maybe a big longer LSA on it.
hognutz
1,940
albany, oregon
Feb 22, 2004
#13
  • Feb 22, 2004
  • #13
double post
hognutz
1,940
albany, oregon
Feb 22, 2004
#14
  • Feb 22, 2004
  • #14
www.vtengines.com or www.modulardepot.com
They have been very helpfull answering my questions.
nickthegenius
1,631
Elwood, IN
Feb 22, 2004
#15
  • Feb 22, 2004
  • #15
Or T&J
http://www.modularfordpowerhouse.com/products.php?id=43
BULLITT#828
60
Austin, TX
Feb 23, 2004
#16
  • Feb 23, 2004
  • #16
Forget the cams. How'd these come out? Pictures?
hahahaha
J/K. Good luck with your more aggressive bumpsticks. Let us know what you gain/lose.
LS2 KLR
452
Houston, TX
Feb 23, 2004
#17
  • Feb 23, 2004
  • #17
Well I've emailed all three of the companies you guys gave me and called two, modular depot didn't have a number on there site. What is sad is no one has replied to my email, nor called me back. I guess they don't want my money!
hognutz
1,940
albany, oregon
Feb 23, 2004
#18
  • Feb 23, 2004
  • #18
PM ken b on the modurlar depot. cobra killer is the main man at t&j you could pm him on this forum. the vt engine guys post on both fourms. they are usually pretty fast.
LS2 KLR
452
Houston, TX
Feb 23, 2004
#19
  • Feb 23, 2004
  • #19
I finally got ahold of Tim at T&J earlier. They are going to get me a custom cam, mainly due to my compression
VTEngine
364
Lansing, MI
Feb 24, 2004
#20
  • Feb 24, 2004
  • #20
I didn't recieve your call Our stage2 cams were designed for combinations like yours, with compression increase (to make up for the tight c/l). To make peak power #'s in naturally aspirated form, you should have tight c/l, because at higher rpms, the tight c/l will acutally help the engine breath. The overlap allows the exhaust to help pull in the intake charge.
1 of 2 Next Last
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
P
Cam spec
  • peter.farina
  • Oct 27, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2024
TOOLOW91
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
D
Cam Choice Time
  • dragstart
  • Apr 16, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 23, 2024
limp
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
