I just rebuilt a second used Holley 600 as my first one had a worn throttle shaft, now the issue. Both Holleys idled at 1200 or higher as the car would really shake at 1000 or less and vacuum would really suffer. A Holley book that I have says "Engines with long-duration camshafts often will not idle at speeds under 1200 rpm." My Crane cam is a mild hydraulic roller with an intake duration of 222 and exhaust of 234. Is this considered a long duration? I have no clue, thanks.
so I purchase a new one, and head home with the engine sputtering. I went to torque the intake (after letting the engine cool down) and only one bolt hit the 25 ft. lbs. with a click. I stopped on the other bolts before I snap one of them. I just hope they come back out! Still there? Now the idle is steady, although still high. A new intake gasket and bolts in the near future. So what size bolts are these, they have a 1/2" head. Thanks.
