  • 1994 - 1995 Specific Tech
Cam install question?
  • Thread starter Thread starter 95YellowGTbeasT
  • Start date Start date Mar 13, 2004
95YellowGTbeasT
605
South Carolina
Mar 13, 2004
  • Mar 13, 2004
Aight im putting and E303 cam in my car. I talked to the summit tech guy on the phone and he said that i need to get a valve spring upgrade kit. I was wondering if this is true, because the lift (498) isnt close to the max lift(512) thats the stock valves can handle without having ot make clearence. Any advice would be much appreciated.
Nick
Joes95GT
3,132
Delaware
Mar 13, 2004
  • Mar 13, 2004
The stock springs are only good for .500 lift, not .512. I would get different springs for many reasons, some of them being more obvious than others.
1) The stockers are tired.
2) The stock springs are probably close to having "just enough" seat pressure to be able to use.
3) The valves are going to float in the higher RPM with the E-cam and the stock valve springs, due to reason(s) 1, 2, and 4.
4) The ramp rates of the E-cam are steeper (quicker) than stock and will probably cause valve float.
It's cheap insurance for 80 bucks or however much they cost.
Joe
95YellowGTbeasT
605
South Carolina
Mar 13, 2004
  • Mar 13, 2004
Thank You
9
94stocker
  • Mar 16, 2004
just something to know when u install the e cam u will get a idle surge so time it correctly and set the idle air control valve with the allen wrench to get the idle just right.or if not u will need a new comp.and harness that pro-m makes for close to 400.00 bucks.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
F
carb vs cam help needed
  • forango
  • May 2, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
