Cam Install
  • Thread starter Thread starter asecretfile
  • Start date Start date May 9, 2007
asecretfile
228
  • May 9, 2007
87 GT speed density soon to be mass air converted. Will I run into problems after the conversion by installing an e303 into an otherwise stock motor?
Thanks
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 9, 2007
  • May 9, 2007
You shouldn't run into any problems but you will not pick up the power potential of the cam because of the restrictive TB and intake.
asecretfile
228
  • May 9, 2007
So I wont have to worry about lift etc?
Thanks
9
90bluegt
592
  • May 9, 2007
Always check the lift to ensure that your not going to hit. Chances are you won't i'm running a pretty high lift cam and i don't hit..
asecretfile
228
  • May 9, 2007
cool thanx
Anyone know where a good place to get a mass air conversion kit short of spending 400.00 for a new one? There's not too many donor cars in my area and as far as getting a part here and a part there, Im not sure of what all to buy for the project. I know I need the mass air meter, computer, wiring harness what else?
Thanks
asecretfile
228
  • May 9, 2007
Forgot to ask, can I use an A9P computer on my 5 speed?
Thanks again
asecretfile
228
  • May 9, 2007
anyone?
M
macjr
18
graham, wa
May 10, 2007
  • May 10, 2007
you will need the pcm, main engine wiring harness, mass air flow sensor and tubing from the air box to the maf and from the maf to the tb. it is best to use the a9l for your five speed. i wish i would have known. just sold a setup on ebay about 2 weeks ago.
vikingpower
656
CWU Ellensburg, WA
May 10, 2007
  • May 10, 2007
You'll need to upgrade your valvesprings, an E303 will only get you major valve float otherwise.
asecretfile
228
#10
  • May 10, 2007
  • #10
does this kit look complete? Its the A9p computer though and I think I need the A9L for my 5 spd
Thanks
P
paintballtommy
244
concord, ca
May 10, 2007
#11
  • May 10, 2007
  • #11
a9p was the standard ford service computer and shoudl work jsut fine.
asecretfile
228
#12
  • May 10, 2007
  • #12
cool thanks, yea hopefully everything shown in that kit is all I'll need
:SNSign:
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
