Just reading the haynes manual, cause I'm contemplating some camshafts for a winter project. It says to remove the timing chain cover you have to remove the oil pan...is this true? Just wondering if I need to have an engine support tool or not.
Removing the front cover only takes a few extra minutes so it's not too bad.Do you know where you can get one of these tools?? Cause if you can change the cam without removing the timing cover that would be awesome.
when you remove those bolts do you have to have the engine held up, or is just 4 bolts that attach to the oil pan?
