cam issue
WFOranger
28
i got a short block dirt cheep from a friend has a comp cam in it part number 35-440-8. i completed the short block with a set of windsor jr heads and a bbk ssi intake but it dosent run right. did some research found out the cam isnt compatable with a computer controled vehicle... is there any way around this? perhapse a computer tune or something.
I don't see any reason that you shouldn't be able to run that camshaft, it is not a large cam by any means the only issue I can see is that it is cut on a 110 lsa, but you should be able to tune around that, most people run cams with 112lsa's due to the computor.
the odd thing is the ford motorsports E cam is the same except for it has less lift. and it says you can use it on a computer controled vehicle... it does say that a modified computer chip may be required. any thoughts?
FYI......
E-303 (CARB exempt cam) = 220°/220° .498"/.498" 110 LSA 110 intake center line
35-440-8 = 220°/220° .512"/.512" 110 LSA 106 intake center line .... or more aggressive lobes than the E-303 however, the valve events @.050" and overlap, are the same as the E-303 advanced 4°.
Need to start by ID'ing what's causing the "symptoms"........ even though a tune is a benefit for your setup, you may have a problem that needs to be corrected first. Have you run the KOEO/KOER self tests?.... vacuum while engine is idling is? LUK
i havent really tested anything... i tried to adjust the timing and tweek the fuel preassure but to no avail. some times it will sit there and idle other times its all over the place. i assume its an issue with the cam but i can understand y i wouldnt be about to use it with a efi settup and a computer controlled distributor
Does the cam changes the times it idles w/out any problem?........ You can use that cam with an EFI setup, but you need to ID what is really causing the current problem, not gue$$.
