  • SN95 4.6L Mustang Tech
cam question
  • Thread starter Thread starter jl04gt
  • Start date Start date Jul 24, 2005
J
jl04gt
26
  • Jul 24, 2005
which cam would be better for 1/4 mile and performance vt stage 2 or comp cams xe270 i am planing on cams some time this month just cant decide which one
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jul 24, 2005
  • Jul 24, 2005
same thing here can't decide which ones to get vt's or comp cams
BLKsteeda
236
Anywhere
Jul 24, 2005
  • Jul 24, 2005
The only thing I have heard about those comps is PTV...I don't know if they got the issue worked out or not. I've read about a lot of people that have had PTV problems and a lot of people that have not. I don't think it's going to make a huge difference in your 1/4 mile time...I'm not sure about the power gains on the Comps but I have heard of power gains of 40+ hp on the VT stage 2's with other proper engine modifications.
hotmustang331
2,967
Bastrop,TX
Jul 24, 2005
  • Jul 24, 2005
Yea, VT stg 2s will make more power N/A vs the comps. With a tune, they generally gain about 10RWHP more than the VT stg 1s with a tune for a total of 40RWHP. But both the 270s and stg 2s WILL LOOSE LOWEND POWER below around 4K. In normal driving the car will "feel" slower. I belive the VT sgt 1s are the only that retain lowend power and then start powering away at around 3500. To answer your Q, VT stg 2s will win in the 1/4 over the 270s....but the margine would be very small. JMO.
billfisher
1,296
huntsville, AL
Jul 24, 2005
  • Jul 24, 2005
I am also trying to decide. I will use modified non-pi heads with the spring seats cut for higher lift. I have used comp cams and crane cams for the 302. I had better results with crane. Crane cams use higher lift than others. VT II's are the cam of choice for the 2v shoot out last month in MMFF. Crane part no Part Number: 379631 is a .600 lift 236/242 @.050 cam. Very radical. hp's going out of style. I will probaly stick to crane. I expect real problems with drivability, but that's HI-PO life.
J
jl04gt
26
  • Jul 24, 2005
so vt stage 1 give you 30 hp just around ten less then the stage 2
BLKsteeda
236
Anywhere
Jul 24, 2005
  • Jul 24, 2005
From what I have heard, the average is anywhere from 20 to 30+ hp.
stangman
2,690
10
69
in a 3 bed, 2 bath
Jul 24, 2005
  • Jul 24, 2005
unless you have headwork there really isn't much power difference between the two cams. now after some headwork, that's where the VT stage 2's really start to shine.
i'm at 280rwhp & 307rwtq with my vt stage 1's. it's not the most anyone has ever made with the stage 1's, but i'm happy with it. & the car is strong through the whole power band
BLKsteeda
236
Anywhere
Jul 24, 2005
  • Jul 24, 2005
I picked up 33rwhp with mine...I will be doing ported heads and headers next month as well as a MAF and larger injectors.
J
jl04gt
26
#10
  • Jul 24, 2005
  • #10
thanks for the info i might just get vt stage 1 because headwork is a long time down the road and did you guys replace the valve springs or keep the stockers in
stangman
2,690
10
69
in a 3 bed, 2 bath
Jul 24, 2005
#11
  • Jul 24, 2005
  • #11
no need to change the stockers with the stage 1 cams, so i still have the stockers
J
jl04gt
26
#12
  • Jul 24, 2005
  • #12
thanks for the help guys i will be ordering some this month
stangman
2,690
10
69
in a 3 bed, 2 bath
Jul 24, 2005
#13
  • Jul 24, 2005
  • #13
www.modularpowerhouse.com
DropTopPony
Noob Slayer
2,570
south jersey
Jul 24, 2005
#14
  • Jul 24, 2005
  • #14
what size injectors are you going with? I was thinking of doing that when i put on the mph 2.5's and vt st2's. I'm thinking 24lber's should do the trick?
stangman
2,690
10
69
in a 3 bed, 2 bath
Jul 24, 2005
#15
  • Jul 24, 2005
  • #15
yup, with that power level that'll do
BLKsteeda
236
Anywhere
Jul 24, 2005
#16
  • Jul 24, 2005
  • #16
I'm bumping up to 24's...and I will also be installing a set of MPH 2.5 heads as well...
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Wednesday at 6:44 PM
DadLife0724
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
