jl04gt said:so vt stage 1 give you 30 hp just around ten less then the stage 2
jl04gt said:thanks for the info i might just get vt stage 1 because headwork is a long time down the road and did you guys replace the valve springs or keep the stockers in
BLKsteeda said:I picked up 33rwhp with mine...I will be doing ported heads and headers next month as well as a MAF and larger injectors.
droptopponynj said:what size injectors are you going with? I was thinking of doing that when i put on the mph 2.5's and vt st2's. I'm thinking 24lber's should do the trick?
