cam question
  • Thread starter Thread starter chucks1967
  • Start date Start date Mar 27, 2008
chucks1967
54
  • Mar 27, 2008
when I bought my 67' the fella' I bought it from said it had a cam..... now natrually it has a cam, but what kind of cam... he didnt know. is there a way to determin the cam specs of an unknown cam?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Mar 27, 2008
  • Mar 27, 2008
Yes there is and I'm sure there is an easier way to do it. They way that I know of is to use a gauge on a magnetic base to measure the cam movement and rotate the engine assembly. I think this can be done by yanking the valve cover and checking the movement of the intake and exhaust rocker arms. Not sure if I'm 100% correct on that. Confermation should come soon....
SadbutTrue
2,391
Thousand Oaks, California
Mar 27, 2008
  • Mar 27, 2008
Yeah, i would think that if you put a breaker bar on the rotating assembly and turned it one full turn and kept your eye on an intake valve (or maybe it'd be easier just looking at the pushrod), you could measure how many degrees out of 360 its open (duration) and you could measure how high the pushrod goes (times your rocker ratio = lift). Repeat for exhaust and you'd have a rough idea of your cam specs. Not sure how practical that'd be, it might just be easier to guesstimate based on what rpms your engine wakes up and when it runs outta breath.
chucks1967
54
  • Mar 27, 2008
I know this is not a really good way of telling if a cam over stock is sittin in my car, but it has a nice cam lope about it at idle. the car really comes alive of the line, arround 1000 RPM and never "runs out of breath" Ive had it up to 5200 RPM and decided to let off because of the age of the motor. even at that rpm it was still pullin' pretty hard. but it feals the strongest from 2500 to 4800.
65kcode
73
Deer Park, WA
Mar 27, 2008
  • Mar 27, 2008
Unless it's a hipo 289, it has a bigger cam than stock from what you are saying.
Kevin
chucks1967
54
  • Mar 27, 2008
To be totally honest I dont realy know that the engine is orrigonal. I took the intake off last night and in the vally pan it was stamped with 302.... I have posted that as a question in another post. I know the car was not a HIPO car it is a "c" code vin. so it must be a taller cam then. now my question is will it make a big difference going to a performer 4bbl intake verses the "stock" 2bbl, cause thats what Im in the process of doing right now. what kind of gain should I be looking at?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Mar 27, 2008
  • Mar 27, 2008
Don't get the regular performer, get an RPM air gap or at least the RPM. Having a 2bbl carb on there before, changing to a 4bbl should give you some extra performance. What carb are you looking to get ?
chucks1967
54
  • Mar 27, 2008
I already have the performer.... and im using a 450 cfm holley m/s
SadbutTrue
2,391
Mar 27, 2008
  • Mar 27, 2008
Unless its already on the car, I'd recommend selling it on ebay and getting an RPM, RPM Air Gap, or Weiand Stealth. You shouldn't lose more than $20 or $30, and I gaurantee you the Performer would hold your cam back.
For small block fords, the Performer is essentially an aluminum version of the stock 4 barrel intake (for Chevy's and some others, the Performer is a legitimate intake, but they half-assed the Ford version).
D
D.Hearne
11,730
south louisiana
Mar 27, 2008
#10
  • Mar 27, 2008
  • #10
Other good intake choices are Ford Racing's A321, Edelbrock's older F4B, The Shelby "Cobra" high rise and Ford's older C9OX. These are all basically clones of each other, and are all high rise dual planes. The difference between these and the ones listed by "SadbutTrue" is the runner configuration, the ones I listed are an "unequal runner length" design where the others have equal length runners. That said, there's not 10 HP difference between all of them. They're all good. And all work from idle to 6500 rpms. You'd want a bigger carb likely though with them. The 450 will work, but may need a larger accellerator pump with these.
H
htwheelz67
444
mission viejo ca.
Mar 27, 2008
#11
  • Mar 27, 2008
  • #11
use an rpm, theres really no difference in power between an rpm and an rpm air gap once the car is warmed up and throw a 650 vac sec speed demon on it.
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 4 5 6
2K
Classic Mustang Specific Tech Today at 11:59 AM
horse sence
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
