cam question?
  • Thread starter Thread starter alvarop
  • Start date Start date May 1, 2008
alvarop
38
Canada Thunder bay
May 1, 2008
  • May 1, 2008
anyone know the firing order of a ford anderson b 451 cam?
Thanks
347HO
462
Seattle
May 1, 2008
  • May 1, 2008
It's on the cam card
alvarop
38
Canada Thunder bay
May 1, 2008
  • May 1, 2008
yes thanks , but i dont have the cam card
Fast63
717
  • May 2, 2008
should be 1-3-7-2-6-5-4-8 if it's roller
347HO
462
Seattle
May 2, 2008
  • May 2, 2008
I had meant to come back with this... my bad, but Fast63 covered it.
alvarop
38
Canada Thunder bay
May 2, 2008
  • May 2, 2008
im having bacing firing problems. in the intake. i have also tried the dist... at 180 also same thing. lots of back fire. i have double checked the plug wires.
i set my balancer a 0 tdc.
how would i know if i have a roller cam?
347HO
462
Seattle
May 2, 2008
  • May 2, 2008
You will need to set TDC and reaccomplish #1. While you're at it... double check your pointer for "0" on the damper.
You will know if you have a roller camshaft by the type of lifters installed. With the intake off, you'd either have the stock "spider" girdle or the aftermarket lifters have link bars that connect them.
If you have neither... then it's anyone's guess.
However! Some people have tried roller lifters on a non roller camshaft with some success. It would be very uncommon and chances are you do not have this setup.
Fast63
717
  • May 3, 2008
if memory serves right, anderson does not make anything but roller cams, so you should be at the firing order mentioned before. Roller lifters can be identified as 347HO described, also double check your timing and marks like he said.
On top of that, put a timing light on it and check it while it's cranking, you should be able to get some readings that way, let us know what you find.
alvarop
38
Canada Thunder bay
May 4, 2008
  • May 4, 2008
I reinstalled my old dist. and checked tdc again, used the same firing order and it fired up. now i have a new big problem , iI will start new thread
thanks
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Y
Dash cam
  • yankeyfan02
  • Sep 15, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 18, 2026
horse sence
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
