cam reccommendation
  • Thread starter Thread starter 93gt1217
  • Start date Start date Apr 3, 2005
9
93gt1217
18
  • Apr 3, 2005
i have a 93 gt lookin for some input for a cam.. recent mods... 3.73s, gt-40 heads, intakes, 70mm tb, 73mm maf, 24# injectors, fms1.6rr's.. thanks
nick
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Apr 3, 2005
  • Apr 3, 2005
Put in and E or B cam and you should pull around 275-285 at the wheels
stock 92 gt
165
  • Apr 3, 2005
whats the differnence between b and e where most torque is?
R
Ray@VSK
355
  • Apr 3, 2005
Basicaly, I would suggest the e over the b though as the b will make your car feel real sluggish down low but if your into saving $ I would have to suggest the Steeda cams as they actually cheaper & better, I'd say get the Steeda #19 but the #18 would work fine aswell.
donkey_punch
565
northern****ingjersey
Apr 3, 2005
  • Apr 3, 2005
how about a crane 2031 cam?
A
ACstang5.0
18
  • Apr 4, 2005
read good things about the TFS stage 1 cam too
oz
1,079
10
58
Plymouth, MI
Apr 4, 2005
  • Apr 4, 2005
I am happy with my cam. Check out my sig.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 4, 2005
  • Apr 4, 2005
comp has some nice cams for your combo..though price is higher. Cost wise the TFS-1 cam is REALLY good for the money. The Alphabet cams are OK but 20yrs old in tech, and there are MUCH better cams available. Call comp tech line or even crane they will get you a good selection if you go that route. I enjoy my choice which is close to OZ's but he has the 114lsa and I run the X#270HR-12 with 112lsa (35-324-8 comp#).
9
93gt1217
18
  • Apr 4, 2005
for the tfs stage 1 would i be able to run stock springs?? and what is trick flows part number for that cam? thanks
9
93gt1217
18
#10
  • Apr 4, 2005
  • #10
would anyone reccomend stock springs?
04sleeper
2,674
14
89
Dallas, TX
Apr 4, 2005
#11
  • Apr 4, 2005
  • #11
First off contact Ed Curtis at FTI. He can help you get the best cam for your combo.
Second. Match your springs to your cam. With your GT-40 heads you have springs good enough to 550 lift.
dstanggt50
1,316
Woodinville, WA
Apr 4, 2005
#12
  • Apr 4, 2005
  • #12
If i were to do it again, I would get a custom cam. If you don't want to go that route, I personally like Lunati cams, but I'm biased. I like mine, sounds good, nice powerband. Had some friends with e-cams, and heard good things about them to.
mustangramair
326
Iowa
Apr 4, 2005
#13
  • Apr 4, 2005
  • #13
I am in the process of putting in a TFS stage 1, i would tell you how i like but its not running yet. I matched it with TFS heads so that is why i purchased it.
90_Red_LX
668
Asheboro, NC
Apr 4, 2005
#14
  • Apr 4, 2005
  • #14
FTI custom cam, if you don't go that route, a AFM-412 (I think thats the number of the cam.)
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
