I didn't degree mine and didn't have any problems but I have the mild Comp 262's using the Anderson tool. I have a friend who put 270's in his with no problems also. Just make sure you are very careful if you go this route.TGJ said:I strongly suggest that you take your time and degree your cams in. You will get the best results with this method. That short-cut method( using Anderson tool ) can cause problems. One of the problems that can arise is that the Cam gears might skip a tooth which could cause you to have Piston to Valve( PTV ) contact. Also the stock Cam gears have a wide tolerance and if yours are out, you could run into PTV as well.
That said I think the biggest thing is the wide tolerance of the stock set-up. If it is off, as much as 6 degrees some have reported, then you may wind up with a problem. Always better to do it right.
