Cam???
Saleen8786
209
Marlton, NJ
hey guys i finally have saved up some cash with x-mas and everything i manage to save cash. So im buying myself something(its from santa) :D . Anyways whcih cam should i pick i have a 91 gt mods are in my sig should i pick an e303 camshaft? Help me decide
thanks
jim
I recommend the trick flow stage 1 cam, its better than the E cam, multiduration is gonna be better for your exhaust ports, it will help them flow better. It has 221/225 dur. @.050 with good lift. No i don't have one, I have the B cam, but i've heard great news about the trick flow cams and they have a good lopey idle with great low and mid with good top end. All around better than the E cam. Just my 2 cents.
Summit sells trick flow. Also, you might want to consider an intake and corresponding mods like maf and tb before a cam, especially your lower intake. I have heard great things about TMoss's ported lower intakes. With the aftermarket heads you have and and a cam, your engine will need to open up it's windpipe to be able to breathe in more air for the heads and cam to flow, and the stock intake will definately be holding back the heads and cam's potential. In any case, I am happy with my TFS1 cam and strongly recommend it. It has a nice lopey idle and great power all the way to 6000 rpm's. Good Luck to you!
