  • 1994 - 1995 Specific Tech
Cam?
  • Thread starter Thread starter sKyZ
  • Start date Start date Jul 24, 2005
sKyZ
138
Scranton PA
Jul 24, 2005
  • Jul 24, 2005
Alright, I decided my next upgrade will be a cam.. Or so I hope. I've never done a cam swap and wanna know how hard it would be to do. A mechanic told me I'd have to remove my radiator to slide the cam in? Also, what cam would you suggest to go with the mods I already have done to the car? Is the cam even worth it or should I go with something else?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 24, 2005
  • Jul 24, 2005
i wouldnt change the cam unless youve got new heads.
just throw some 1.7rockers on with your stock cam to get some more lift out of it
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jul 24, 2005
  • Jul 24, 2005
stock heads=stock cam. optional 1.7RR.
sKyZ
138
Scranton PA
Jul 24, 2005
  • Jul 24, 2005
what would 1.7 rockers do for me?
I
igotyofire
774
Southern California
Jul 24, 2005
  • Jul 24, 2005
i belive its 1.7 times advertised Lift, instead of 1.6 times advertised lift....heh 1.7 will get u bit more cam without actually changin the cam
TrueBlue95GT
966
Connecticut
Jul 25, 2005
  • Jul 25, 2005
First, you should be looking at an intake manifold and gears.
a50sn95
368
Elk Grove, CA
Jul 25, 2005
  • Jul 25, 2005
Agreed. Intake and gears first (although I didn't....) A cam change will likely bring drivability issues you will HATE (poor idle, stalling), unless you've got some way to adjust for it (custom tune.) Besides the True Street guys are running in the 10's with a "Stock" cam.
To answer your question about the job, you can do it by pulling the upper intake, the valve covers, the front cover, remove the radiator, the distributor, rotate the AC condensor up out of the way, get the AFM lifter holder kit, and swap away. It's a full day for an experinced mechanic in a hurry, a weekend if done casually. If you don't get the AFM kit, then the lower intake has to come off as well, the lifter spider and all the lifers. Interstingly, the front dress (alternator, PSpump, etc) can stay on since they bolt to the head, not the timing coever like the older Mustangs.....
I wouldn't do it, yet....
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 5 6 7
2K
Classic Mustang Specific Tech Today at 6:04 AM
GOvert
G
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
