Save your money. By the time you buy your cams and springs, pay for the install, and then the tune, you have nearly spent the same amount as purchasing a forged crank, rods, pistons, and rings.
Cost for CAMS:
$599 ie $600 for cams
$199 ie $200 for springs
$300 for the install
$300 for dynotime plus tuner fee
Total - $1400
Cost for Forged rotating assembly components:
$600 for a new Cobra Crankshaft <$400 at online auctions
$500 for Pistons
$500 for rods
$200 for rings
Total - $1600-1800
Build it safe and build it right...Please, be patient - if you go forged first, just turn up the boost a few pounds and you will have the power the cams would have given you at the cost of a pulley. If you put those cams in with how you are now, it makes you that much more likely to have something bad happen. Throwing a rod through the block will set you back a lot more than taking your time to build it right.
As to a set of blower cams increasing boost down low being a positive selling point, that is just ridiculous. A good set of cams should actually give you a boost DECREASE across the entire RPM range. Boost does not mean power, it is more an expression of how much work the supercharger is doing. CFM does not necessarily mean power, but is a factor in potential power. This applies to heads, intake, throttlebody, etc. Even increasing exhaust flow will lower boost. The only things that will increase boost at any given RPM are an increase in blower speed compared to engine speed, increasing one of the many efficiencies of the supercharger, or introducing a restriction into the inlet system after the supercharger.
A supercharger is a linear speed pump whether it is centrifugal or positive displacement. This means, barring belt slip, it is spinning at some mathmatical ratio of engine speed. All superchargers and turbos, negating leakage, are designed to move a set amount of air through their casing per revolution of their impeller. Different designs have different characteristics of leakage. This affects just one of the many different efficiencies associated with a particular design.
If the supercharger is flowing X amount of air and the engine injests Y amount at atmospheric pressure then the manifold pressure will be X/Y and is easily expressed in BARs (that is how they measure boost in europe). If you increase the air flow capacity of the engine - then Y goes up. So boost will actually go DOWN even though you may be flowing more air with less work done by the supercharger. Strange but true. You can see it very easily if you compare two sets of cylinder heads that have different flow numbers. The higher flowing set will nearly always register less boost, all other things being equal.
Sorry about the rant, just trying to look out for enthusiasts and help fix concept errors. Anybody trying to sell an item other than a supercharger pulley or a different supercharger, on the basis that it raises boost with everything else being the same, is taking you for a ride.
Hope this helps.
Wow, sounds like you're just spouting off a bunch of obvious stuff to make you argument sound articulate. I never said it'd make more boost, i said it can help make boost lower in the rpm's depending on the cam. Seriously, re-read my post. If my cam has a low duration and large overlap like my current stage 1's do and i switch to a blower cam with more duration but less overlap it'll help build boost down low but im not saying it'll make more peak boost. And, given, most blower cams (especially for centri's) push power up higher - that's why I said depending on the cam.
I don't know why you're bringing up CFM and boost I wasn't even referring to any of that.
I can tell you've done a lot of reading, but no need to try to lecture someone who's bought N/A cams, bought superhcarger cams, and installed them/tuned them about what they do.
Coming from someone who built their own shortblock as well, I can tell you your math might be a bit off too.
You left out a few things, like how you added labor on the cam install but left it out for the shortblock when that's the most expensive part being that you're doing more work than an engine swap since you need to swap + dissasemble and assemble.
"Cost for Forged rotating assembly components:
$500 for Pistons
$500 for rods
$200 for rings
Total - $1600-1800"
is more like:
$500-600 for Pistons
$430-550 for rods
$140 for rings
$95 for main bearings
$90 for rod bearings
$150 for balancing assembly
$50 for new sidebolts or MMR sidebolts
$45-110 for new main bolts or ARP mains
$120-250 for New headgasket and head install kit or + ARP headstuds
$400-650 For professional assembly of shortblock
$900-1600 for professional to do the engine swap
= $2890 (if you're lucky) or $3885 with more realistic prices and labor plus some wise extras.
Then if you have some miles on your block it's $300 for a bore/torque plate hone. If you tell someone a forged shortblock build is similar in prices to cams, their going to be pretty pissed off half way through doing the build.
And let me say I'm not implying you don't have any experience or have useful info, just that you're aguing against a straw man fallacy you created - not anything I brought up.
