DrK MrK iV said:
So duration gives me the idle? I thought lope did. I also heard that I don't want to go over 500 degrees with stock valve springs.
First off, a quick lesson in camshaft lingo.
duration- measurement in degrees for how long the valve stays open
lift- measurement in inches for how far open the camshaft is lifted away from the valveseat.
lope- just a term to describe a choppy idle
With that out of the way, there are only 360* in a circle. 500* of duration would call for some creative grinding.
What you are looking for in a cam that can use the stock valve springs is something that stays around .500" lift. The stock PI cams are actually higher lift than that, but most of the aftermarket camshafts for the 4.6L are either right at .495"-.500" lift or .550"-.560" lift depending on whether they are intended for NPI or PI heads. What you could do, it get a set of camshafts custom ground with the stock PI lift numbers (which are just north of .500, but can't remember exactly) and get more duration and get something like a 110*-113* lobe seperation angle.
So what you could do is get someone like Comp or T&J to grind custom some cams with specs like:
230*/234* duration @.050
113* LSA
.517"/.525" Lift <---PI lift specs are something like that
That way you have the benefits of more duration and get to retain the higher lift of the PI cams instead of short-changing yourself with NPI-style .500" lift cams.
