94GTLaserRC said:
This car could not then be a DD could it?
RC
First of all, as always, I got a thought or two
This is a pretty max effort project IMHO ... I mean ... Look at some of this stuff and I think you will agree ... it took LOTS of cash AND this combo is the exception to the rule.
1) I am using the factory '93 block with a DSS girdle, an Eagle crank and H-beam rods, and Ross pistons(shelf stock, not custom). The machining was just the standard cleanup, nothing exotic was done(vibration, coatings, thermal treatment, etc.). The rotating assembly was balanced using a 28oz imbalance(wrong crank was shipped and he made it work) I hand fitted my JE rings.
2) TEA Stage III Renegade Twisted Wedges
3) CompCams Titanuim retainers
4) Holley intake is also TEA's full Renegade port job, with #s 1 and 5 welded to straighten them out
5) The cam is an FTI custom
6) Bassani 1 3/4"to 1 7/8" stepped headers with 3" collectors
7) factory T-5
8) I tune with a PMS
Just a comment on each point
1 Purpose built motor ... I'm not gonna be using a motor at that level to just get around town
2 Not your run of the mill, average set of TFS heads ...Lotta Cash
3 Those ain't cheap
4 Same kinda thing as point #2
5 This shows his commitment to follow Ed's recommendations which are all about ... results first ... and cash spent is NOT the top priority in situations like this one
6 Very spendy and hang LOW ... not the best choice for a street car
7 I mention this as it will help the dyno results but it ain't as tough as other stick trans choices that would show a tad lower dyno numbers
8 I could go on and on here ... but only a comment or two
a) He laid out the necessary cash for the equipment to be ABLE to tune it for the BEST results possible
b) Look at his post about tuning day at the dyno ... MAJOR CASH
Summing up ...... To my way of thinking ...................
Daily Driver?
Sneek it out on the street every now and then
You'd better believe it
Grady
