Can a T-rex be used to supplement the stock fuel pump?
Nobody
2,515
Kenmore, WA
I am considering just using a T-rex instead of installing a new in-tank fuel pump for a 125 shot of nitrous. I have had a couple shops tell me that this should be fine. I was wondering if it really is fine. I am not sure how a T-rex would increase the volume of fuel if it's noly being fed by a 110lph pump.
Don't get the T-Rex. They are good pumps and all, but overkill for your application. The only reason I would buy a T-Rex is if I had >=42 lbs injectors and already had a 255 in tank. It will work, but they are expensive. Instead I would just buy a 255 in tank pump, either way you have to take the gas tank off, and the T-Rex requires some drilling of holes and bracket mounting along with running a wire to the fuse box. So your really saving yourself a lot of time and money. T-Rex: ~$250, 255 in tank: $125 -> save your money.
