- Oct 9, 2003
- 968
- 1
- 17
I believed that I have overtightened my lower intake (http://forums.stangnet.com/showthread.php?t=590101). Can this result in the heads being shifted/spread apart?
Thanks,
Rick
Thanks,
Rick
Yeah i agree, and plus the fact that the intake only usually is torqued to around 12 ftlbs so over torqued would be around 20ftlbs or so. PLUS the fact that you are running AFR heads which have aluminum threads i would be you would strip the threads out before you moved the heads.divit250r said:Wouldn't the dowels in the block make it impossible to move the heads at all?
Scott
blk9450 said:its not that it MOVES the heads, but it places a static force on them. the tension causes head gaskets to blow easier because there is less force claming head to block becuase of the tension forces from the manifold blots pulling up. i dont have a link and im too lazy to look, but its common knowledge over there
It's a dynamic force - else the head wouldn't be getting yanked that little bit.blk9450 said:its not that it MOVES the heads, but it places a static force on them. the tension causes head gaskets to blow easier because there is less force claming head to block becuase of the tension forces from the manifold blots pulling up. i dont have a link and im too lazy to look, but its common knowledge over there
well joe maybe you slept through that class. dynamics involves moving objects and statics involves forces with no movement. as i said before, the head doesnt move, its just under a force, that effectively decreases the force holding the head down.Joes95GT said:It's a dynamic force - else the head wouldn't be getting yanked that little bit.
And I don't think it'll make a bit of difference if the intake bolts are over tightened slightly.
Joe
I didn't sleep, I actually tried - I failed it twice and dropped it once.blk9450 said:well joe maybe you slept through that class. dynamics involves moving objects and statics involves forces with no movement. as i said before, the head doesnt move, its just under a force, that effectively decreases the force holding the head down.
Isn't 80 ft-lbs with a head bolt much different than 80 ft-lbs with a tiny lower manifold bolt. Something about moments or something?! Seriously, I'm not being a smartass - I really only know half of what I'm talking about when it comes to this book-smart crap.
Joes95GT said:I didn't sleep, I actually tried - I failed it twice and dropped it once.
If it's decreasing the force holding the head down, there has to be some kind of movement, correct?
And, doesn't the size of the bolt have anything to do with the magnitude of the force? (Or something)Isn't 80 ft-lbs with a head bolt much different than 80 ft-lbs with a tiny lower manifold bolt. Something about moments or something?! Seriously, I'm not being a smartass - I really only know half of what I'm talking about when it comes to this book-smart crap.
I don't think that 5 extra ft-lbs on a lower manifold bolt would cause any harm whatsoever. Regardless of what physics tells you, it's not really what happens. There's a lot more (important stuff) to a blown HG than a slightly over-tightened manifold bolt.
Joe
blk9450 said:well say there is a 200 lb weight on the floor, and you have a rope on it and youre trying to pick it up, if you get a girl to help you that can lift 50lbs, then you only have to lift 150lbs to get it off the floor. same thing with the head. the bolt is the girl. the more she lifts, easier it is to lift the head (weight)..
doesnt matter how big the bolt is, or the girls arms, 50lbs is 50lbs.
5 extra ft lbs , per bolt times 10 bolts (i think) per side. it adds up
rick, what do you mean lifting of intake? true it will counteract the intake coming up, but this also is the force that pulls the heads at a 45 degree angle up
