K Kid Capri Founding Member Dec 28, 1999 275 0 17 Jan 1, 2005 #1 Jan 1, 2005 #1 Does anyone know the # of teeth on the ring gear and the pinion for 3:55 gears? If you could share the info. I would greatly appreciate it. Thanks
axeman Founding Member Feb 9, 2001 1,348 0 36 Elizabethtown, PA Jan 1, 2005 #2 Jan 1, 2005 #2 divide number of ring gear teeth by number of pinion teeth. in this case, the ring gear has 39, and the pinion has 11.
TRWXXA Member Jan 18, 2003 190 1 19 RIGHT BEHIND YOU!!!... Made you look. www.superford.org Jan 2, 2005 #3 Jan 2, 2005 #3 Oops.
