Can Fuel Injectors be saved?
All,
New to the site here. First let me apologize if there is some older post about the same problems, I haven't had much time to search thru all of the older post.
I have a '74 Datsun 260Z with a 347 stroker and EFI that was brought to Japan in 2005 and was only driven about 200 miles and then sat for about 3 or 4 years. Before it was parked, everything was NEW! Seriously, a project car, $20K, 50% finished, MAYBE 1,000 miles total and it has been sitting for years.
Since then I have divorced, remarried, had my first child (at age 39), and started my 3 tour-of-duty in Japan. It might be a mid-life crisis, but now I've decided to register this car in Japan. Wifey said that we need a second vehicle?!?
My problem is that now the car will not start. Big suprise? So, new battery, oil and fresh gas. It has spark, fuel pressure and oil pressure. But it seems that the fuel injectors are not "injecting" fuel. Cranked the engine over several times. The spark plugs are not wet, they don't smell like fuel and there is no smell of fuel at the tail pipe. When I blead the fuel out of the rails there was old fuel in the fuel rails that didn't really smell like fuel anymore. A co-worker (fellow gearhead) said to soak the injectors in fuel injector cleaner which I did today.
Now my question is: Is the injectors the cause of the problem and is there any hope of saving them by soaking them in Fuel Injector Cleaner? Will it damage the plastic connector or the rubber o-rings?
Thanks,
Mark
Maybe I am crazy but it seems odd that all of them stopped working, maybe it is something wiring or ecu related? I had a Camaro that was in storage for about 7 years, kind of the same deal. car had been completely restored and was flawless. Bought it dirt cheap because the owner could not get it to run after it was stored so long. I towed it home and discovered some animal had chewed some wiring. A solder gun, wire and a couple hours were all it took to make it fire up. Not saying that is it but just something to check out...
...I have a '74 Datsun 260Z with a 347 stroker and EFI that was brought to Japan in 2005...
I can understand why the Datsun I-6 engine is gone. It was the worst year, ever for that engine. I almost bought the 260Z, new, it ran so badly on the test drive, told the dealer to keep it, "deal is off". There was a waiting list for them back then, I waited 4 months. They only made the 260 for 1 year, it had three 2-barrel carbs. All fuel lines & carb bowls wrapped in asbestos-type insulation. Because intake & exhaust were on the same side, heat from exhaust boiled the fuel in the fuel lines & carbs, resulting in vapor lock almost all the time. Anyway, just thought you might like to know a bit of history on the 260Z. 240Z was the best of the lot.
http://auto.howstuffworks.com/datsun-sports-cars2.htm
"...With 150 bhp (SAE net), the larger engine brought performance back to near 240 levels, and Nissan responded to complaints of poor Datsun 260 engine driveability by junking carburetors in favor of Bosch electronic fuel injection..."
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 28-Nov-2011 to update the Fuel pump test jumper diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
C.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
D.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
salt-pepper-10-pin-connectors-65-jpg.68512
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
All,
Thanks for the feedback. Bigger injectors, flowed, etc. will happen in time. First, I have to get this thing registered or it will be sitting for another 3 years.
Spark is good and Fuel pressure is good. I agree that it seems odd that all eight injectors would fail simultaneously. The smell of the fuel that was in the fuel rails was really odd. That’s why it seemed to me that the injectors were the problem.
So, with the exception of starting fluid to verify that it will light off, everything has been verified up to step 5. This “noid” is it Ford, Mustang, EEC-IV specific? Because the parts stores here in Japan are NOTHING like the U.S. and even more difficult since it’s a Ford. However, I do have a Fluke Meter to check the 12vdc on the injectors and the TPS voltage.
If the injectors were “gummed” up and hoping that this is what’s wrong, how long should these injectors soak?
Jrichker: Thanks for the detailed checklist. Is that from a book, or did you write all of that up?
VibrantRedGT: There are some pictures here: http://www.cardomain.com/ride/771320/1975-datsun-260z
Mark
Very cool write up. Can't believe it sat for 7 years after all that work. You're going to have take the fuel tank out for cleaning, blow out / clean all fuel lines, install new fuel pump and either redo the injectors or get new ones.
... This “noid” is it Ford, Mustang, EEC-IV specific? Because the parts stores here in Japan are NOTHING like the U.S. and even more difficult since it’s a Ford. However, I do have a Fluke Meter to check the 12vdc on the injectors and the TPS voltage.
NOID Light: http://www.lislecorp.com/divisions/products/?product=141
Exactly what you need to check for signal to the injectors. Fluke too slow to respond, unless it has analog scale which is still a bit slow. Also difficult to crank engine while holding probes in position. I just bought one from Amazon, haven't tried it. Hope I don't need to.
The write ups that I post are my original work. Where I quote or borrow something I try to give credit to the person or company I got it from.
So, got everything put back together last night. It started but was running like crap and kinda sounded like a Harley. Not saying a harley sounds like crap, just saying a SBF shouldn't sound like that. After about an hour, it seemed to smooth out.
Fuel pressure should be set at 39 psi?
According to Pro-M:
http://www.promracing.com/the-facts-about-mass-air-flow-meters-page-9
This seems to be saying all others are no good except for Pro-M. If this were the case, why are the companies they are referring to still in business after 20 years? They didn't name any names due to liability issues but if a company has to go to these lengths to prove their product is superior, I tend to not believe their claims.
Your Tweecer can perform the needed recalibration.
Both the TwEECer and TwEECer RT provide the same tuning capabilities, allowing you to adjust the calibration for changes in Engine Displacement, Injector Size, MAF "Calibration", Spark Advance, Electronic Transmission adjustments and much more.
Interesting ... return your Non Pro-M Racing MAF for repair/ recalibration 3 times and you have paid for the best tweecer software package they sell. That's some motivation to acquire one if you already have Windows XP SP3 or better on a good laptop.
