can hear fuel pump but no fuel!
88GTMustang
247
LA california
I can hear it pump for a few seconds when i turn the key but i have no gas going to my engine and i took a gas line off and tried it not even a drop. i know tthe lines arnt pinched or anything so does this mean i need a new fuel pump or is there something else i could check for?
If you drop the tank you could make sure the pump has all the rubber tubing connected inside the tank, or check the fuel filter as well if it has been changed in awhile.
If you prime it with the tank down and get no fuel from the pick-up it needs a new pump.
