Can I convert to manual brakes
revhead347
Apparently my ex-husband made that mistake.
Jun 14, 2004
9,303
1,649
214
Acworth, GA
My motor only sucks 9" of vacuum at idle, and even with 2 reservoirs I have brake troubles sometimes. Can I switch to manual brakes and still maintain my ABS. I can't afford to put a vacuum pump in yet.
Kurt
I'm thinking what's needed is a larger piston in the master cylinder or more leverage at the pedal, assuming you've done the basics like bleeding the system and installed a quality set of pads. Note if you're using NoiseStop or PrettyWheel brake pads you're not getting maximum brake force.
ABS shouldn't come into question, I don't reckon. All it's interested in is the brake line pressure, it doesn't care how that pressure is created.
It's a neat question. I hope you can get more discussion going. Good luck.
Actually, I have a set of Hawk brake pads from Steeda. I have a vacuum gauge hooked up to my reservoirs. If I have 16" of vacuum, then the brakes work great. But if it drops down to 9", then they don't work so well. I know that they make manual brake conversions for older fox stangs. You pretty much just change the master cylinder. In theory, it should work the same on an ABS car.
Kurt
