QDRHRSE
300 fwhp will get you to the mid 12's in a 3000lb car....that translates out to around 255 rwhp. 325 fwhp (276 rwhp) will get that same car into the bottom 12's. It's funny because I keep hearing about all these 300hp GT40 combo's but rarely does it look that way when people go to the track. I also find it unusual that I have never seen chassis dyno numbers for a 300hp GT40/Cobra Intake/65mm/Ecam combo?
Notchback-
Your a twit. Your friend going 11.80's is a hair above the 300 hp mark with a 125 shot. I'm confused. Your point is? Your friend needs a 125 shot to do a tad better then you say he should be doing on the motor...help me out here.
I pride myself on being realistic. You want 300rwhp out of gt40 set up? Yeah, I guess you could do it, however, the port work alone would run more than a set of Twisted Wedge heads. If you are talking at the crank then its a done deal. Then you add in the fact that this guy wants to use a Cobra intake and an E cam.....come on guys.....that combo will make more TQ than HP! It's not a bad combo....just not 300fwhp.
Notchback-
$600 can get you a used set of aluminum heads. Not only do you get the flow, you also drop 50 pounds of weight.
