Can not run codes with the engine running
Camman
1,055
Las Vegas, NV
Hello, I have codes 22 and 67 with koeo tests. I try to do the engine running tests and I get nothing. When I ground the sti the engine almost dies, then it revs up to about 3000 rpm then slowly idles back down, then it just kicks on the mil and does nothing else. Am I doing something wrong? Is my car jacked up? Thanks for the help guys!!
when i was at my friends shop a week ago. i pulled the following codes... and also couldnt get a self test to run.
67.
85.
91.
185.
Code 67 - Improper signals are being received from either the Neutral Drive Switch (NDS),Neutral Gear Switch (NGS),Neutral Pressure Switch (NPS),Clutch Switch (CS),Manual Lever Position Sensor or Air Conditioner Clutch.
rest of the thread is over here: http://forums.stangnet.com/showthread.php?t=401096
