  • 1994 - 1995 Specific Tech
Can pushrod Mustang parts work on F250/350's?
  • Thread starter Thread starter fawcett
  • Start date Start date Sep 5, 2011
fawcett
380
Cohasset, Ma
Sep 5, 2011
  • Sep 5, 2011
I've been thinking about upgrading my heads in the future and wasn't to sure if I wanted to try to sell them. I'm looking for a third work truck for my business and I want to know if our intakes/heads/cams/injectors would work on an older 302 or (most likely) a 351W found in a F250/350?
How different or similar are the ECU's?
Thank you,
Fawcett
Adam95GT
2,564
Burlington, NJ
Sep 6, 2011
  • Sep 6, 2011
Lower intakes are different due to the 351w deck height
Adam95GT
2,564
Burlington, NJ
Sep 6, 2011
  • Sep 6, 2011
Oh and your most likely dealing with non rollers.
fawcett
380
Cohasset, Ma
Sep 6, 2011
  • Sep 6, 2011
So an 351w intake that would fit on a mustang wouldnt fit a 351w in a f250/350?
Are all of the truck 351w's built with a non roller type of valvetrain?
What about exhaust headers?
I'm still wondering about the computer differences as well.
fawcett
380
Cohasset, Ma
Sep 16, 2011
  • Sep 16, 2011
Anyone?
Looking to put my GT-40X heads on a 351w found in 1992-1997 F250 and F350's?
Will it work, any problems? Can I also go with a 351w style intake (ex: trick flow r comes to mind)
Fawcett
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 16, 2011
  • Sep 16, 2011
IIRC, if it's a 1994 or newer engine, it will be roller. It might be 1993, but I'm not certain. Otherwise, the 302 heads will swap right over, as long as the head bolt holes are drilled out to 1/2" for the 351. If it's a roller block, the cam will interchange, too. You'll need some new pushrods and a lower intake, but basically everything is compatible on the top end.
fawcett
380
Cohasset, Ma
Sep 16, 2011
  • Sep 16, 2011
Cool, I ask because most trucks I've been looking at have exhaust manifold leaks and other issues with their exhaust systems.
I hope that I can remove the old heads & manifolds, install a new set of manifolds on my GT40X heads on a bench (out of the truck) then install the heads with the manifolds on already.
Should be easier right?
Plus, MOOOORRRREEEEE POOOOOOWWWWEEEERRRRRRRRRR!!!!!!!!!!!!!!!!!!
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
  • JRC99
  • Apr 19, 2025
JRC99
J
