LocoStrange said:The car is good, but it probably wont be for long. You probably just weakening the gears VERY badly by that. Meaning, you probably shorten the life span of the gear. How long? Who knows but dont be surprised if it happens soon![]()
You could have saved some time by simply typing "I KNOW NOTHING ABOUT CARS SO IGNORE THIS POST."
The fear in a situation like this isn't "weakening the gears VERY badly". That doesn't make sense. The gears don't have a defined lifespan. If they are not abused day in an day out, are well lubricated, and don't corrode.... they will last practically forever. Can you break them? Sure. But then they just break. They don't work for three weeks and THEN break.
The concern here is a mechanical over-rev of the engine. At extremely high engine RPM, the timing chains will stretch against the force of the chain tensioner. Because the cam will obviously change valve timing under these circumstances, you wind up with piston-to-valve interface. The valves lose. You now have a trashed valvetrain and trash itself in the cylinder bores.
If the engine runs strong and sounds good he is probably all right. Most serious engine problems announce themselves immediately, kind of like an STD.
Glad your cars alright!
