Can someone give me torque specs plz
69stanger
102
CA
I just installed my new cam and i want to close it back up but need some torque specs since the Hayes Repair Manuel dosent give many of them :notnice:
can someone give me the torque specs for the following:
1) camshaft thrust plate
2) fuel pump eccentric
3) timing house cover
4) crankshaft damper
5) damper pully
6) water pump
thanks so much
5) damper pully
6) water pump
thanks so much
The only ones I've ever torqued to spec are the eccentric bolt, the damper bolt. The others are tightened bt "feel" Use thread locking compound on the thrust plate bolts and eccentric bolt. Some of the water pump bolts need thread sealer too, they are open to the water jacket on the backside.
