I did the 5.0 conversion using the motor, computer and harness out of a 91 GT Automatic. I have the A9P computer and per the Ford Dealership the computer is ok, and from the correct car. I am having trouble with the wiring, as the wire colors don't match the schematics. I don't have power to Pin 22, or to the fuel pump relay, but the computer does have power to it's relay.
Here is what I have: Blue/orange wire from pin 22 running out to the EEC test port, and back to a grey plug under the dash that carries the fog lights wiring (4 wires), a Tan/Yellow wire which runs back to the Fuel pump relay, and a red wire which joins a group/splice of about 5 red wires in the harness (this group includes the red wires from the ECU Relay- which do not have power with key on)
On the Fuel pump relay, I have the following wires: Red - 30 (runs back to the harness splice with the other red wires, Black/orange to 85, the tan/yellow wire from plug above to 87 and tan or grey/lt blue at 87a.
When the key is turned on (not start) I should have power to 30 but I don't. Can I just run a wire from 30 straight to the (+) on the Solenoid? Is there anything in the fuel pump relay circuit that is going to cause me issues, if I just isolate it, using the wire from pin 22 to switch the relay?
I just don't have any more money to spend to bring it to someone. Is there a wiring guru that can help me out? Thanks.
