can someone point me to a tutorial on rear main seal replacement?
DrSmith
181
Maine
I have searched on the web and can't find what I am looking for, my manual isn't that great. I need to know what tools to buy and torque specs. Another site said they had a stickey on it, but I can't find it.
Thanks guys. I tried to post pictures of my proud son with the car, but it failed to load....
Doc
You can usually get the old main out with little more than a screwdriver. If not, screw a self-tapping screw into the face of the old seal to give you something to lever on in order to get it out.
If once you get it removed, the old seal is still somewhat in one piece, you can use it to tap in the new seal.
The flat side of the new seal faces out... the spring side faces in... place the flat face of the old seal against the flat face of the new seal and tap it in (all the way around), with a mallet.
What torque specs are you looking for?
As far as tools go... you need everything necessary to pull the driveshaft and tranny out of the car. That of course means removing the H-pipe. I recommend having some loooooooong 3/8 socket extensions and a unerversal joint for the tranny and bellhousing. I usually pull the tranny out of the bell housing first then pull the housing.
You'll also need a pretty healthy breaker bar and some 12 point sockets to pull the driveshaft. Be sure to MARK THE CLOCKED POSITION of the driveshaft before you remove it, so that it can be reinstalled in the same position.
Driveshaft bolts get RED Loktite and are torqued to the GOOTANTITE spec. Forget about torque specs on the bellhousing and tranny as you won't likely get a torque wrench in there anyway. Use good sense.
Oh... and remove the shifter before you pull the tranny and cap the end of the tranny after pulling the drive shaft but before you pully the tranny itself. T5s take MERCON.
Someone will come along and help out if I've missed something.
Good Luck! :nice:
Doc
What part of Maine are you from. I might be able to help you out if needed
Yep
And get a clutch alignment tool if you don't already have one. You WILL need the torque specs for the flywheel and pressure plate. If I remember right, it was 85 ft/lbs for the flywheel... don't quote me.
Rear main engine oil seal, Transmission and Clutch replacement 79-95 V8 Mustangs
Before you get started, buy a Chilton or Haynes shop manual. You will need it for the bolt torques and patterns.
1.) Jack up the car front and rear, use jack stands to be safe. I use some very tall jackstands that I bought for my wife’s SUV to get enough clearance. To get the trans out when using a transmission jack, you will need 22”-25” clearance.
2.) Put a 2x4 wood block under the engine oil pan to support the engine. Jack it up slightly. This prevents damage to the motor mounts when the transmission mount is removed. The oil pan is plenty strong for this purpose. Disconnect the negative battery cable. You will need a couple of extensions and a ½” swivel socket to remove the top starter mount bolt, which is accessed from the front and under the headers. Leave the starter wiring connected unless you plan to change the starter at this time.
3.) Label all the wiring for the transmission before disconnecting it. Disconnect the O2 sensor cables at their connectors. Disconnect the speedo cable by pulling it straight out of the VSS sensor, or by removing the bolt that holds the VSS sensor in place. If you remove the VSS sensor, zip bag & tag it along with the bolt that secures in place.
4.) Remove the drive shaft, the rear bolts are 12 MM. You will need a high quality 12 point wrench for this: do not skimp or you risk rounding off the bolt heads. A helper to step on the brake to keep the drive shaft from turning will be helpful. Use your foot to apply pressure to the wrench to loosen the bolts. Note the yellow markings in the drive shaft and write down their alignment.
5.) Put a catch pan under the rear of the transmission to catch the fluid when you slide the yoke out of the transmission. I recommend that you drain the transmission at this time. There is a pair of pipe plug filler ports on the side of the transmission. Use the lower plug to drain the fluid.
6.) Inside the car, remove the shifter boot and then remove the shifter handle
7.) Remove the H pipe & rear trans cross member. The chassis to cross member bolts are metric, you need a 15 MM & 17 MM socket or wrench. Note the direction and size of the humps on the cross member and write it down. Inspect the rear transmission mount and replace if damaged.
8.) Remove the transmission. You will need a long extension & a universal joint with a ¾” socket. A transmission jack or a helper is almost a must have unless you can bench press 75-100 pounds with ease.
Steps 9-21 are for rear main engine oil seal, clutch removal and replacement.
9.) Remove the clutch cable cover and pry the throwout bearing arm forward enough to slide the cable off.
10.Remove the bell housing using the long extension & a universal joint socket. Note how the throwout bearing rides it the throwout bearing arm, and which end faces the clutch pressure plate. Write it down or make a drawing if necessary.
11.) Remove the bolts securing the pressure plate to flywheel. Be sure to label & zip bag them separately from the rest of the parts. Work in a star pattern to reduce stress on the pressure plate mounting tabs.
12.) Remove the flywheel mount bolts, as you will need to either replace or re-surface the flywheel. Be sure to label & zip bag them separately from the rest of the parts. Tap the locator dowels out of the flywheel with a 1/4" pin punch. Zip bag them together with the flywheel bolts.
13.) Inspect the transmission input shaft where the throwout bearing rides. Replace it if worn or damaged.
14.) Inspect the throwout bearing, throwout bearing arm and ball pivot stud for wear or damage.
15.) Inspect the rear oil seal for leakage and replace if required. A pair of drywall screws carefully screwed into the metal part of the seal will enable you to pull it out. Use some acetone & swabs to clean out the place where the old seal fit. Coat the outer metal shell with silicone gasket maker prior to installing it. Use a seal driver or the old seal to drive the new seal in place.
16.) Remove & replace the pilot bearing. A puller borrowed or rented is helpful here. A wood block will be used to drive it home.
17.) Install the flywheel, noting that the bolts are an odd pattern, and it only lines up one way so that all the bolts go in easily. Torque to specs according to the shop manual. Install the locator dowels at this time.
18.) Install the clutch disk with the hub springs facing the rear of the car. Use a pilot tool available for $3-$4 from the auto parts store to line it up.
19. Install the pressure plate, be sure to use the pilot tool prior to tightening the pressure plate bolts. Torque to specs according to the shop manual. Remove the pilot tool when you are finished torquing the bolts.
20.) Install the throwout bearing on the throwout bearing arm, noting the direction of the bearing and it mounting in the arm.
21.) Install the bell housing. Torque to specs according to the shop manual.
End of clutch replacement steps
22. Install the transmission, have the transmission jack or helper at hand to lift it into place. Watch out that the stub of the shifter does not tear the shifter boot. Some transmission mount bolts with the heads cut off can be used to help support the transmission as you slide it home. It may be necessary to press the clutch pedal to get the transmission to slide the last ½” or so. Remove the guide studs if you used them & torque to specs according to the shop manual.
23.) Reinstall the clutch cable by prying on the throwout bearing arm. Replacement of the stock cable or quadrant is recommended if you haven’t already done so. With adjustable cables, both nuts go on the back side of the throwout bearing arm.
24.) Reinstall the rear crossmember & transmission mount. Torque to specs according to the shop manual.
25.) Reinstall the wiring and speedo cable or VSS sensor if you removed it.
26.) Reinstall the drive shaft, slide the yoke in place. Align the rear yellow markings and install the bolts. A helper to step on the brake to keep the drive shaft from turning will be helpful. Use your foot to apply pressure to the wrench to tighten the bolts.
27.) Remove the jack from under the engine oil pan.
28.) Refill the transmission with the proper fluid. T5’s use Dextron ATF, Tremec 3550’s use GM Synchromesh. There is a pair of pipe plug filler ports on the side of the transmission. Use the top plug as the filler port.
29.) Adjust the clutch cable according the manufacturer’s instructions if you have an adjustable cable & quadrant. Set the emergency brake and use the drag it provides in order to determine where the clutch starts to engage. You should have 1 -1 ½” free play from the top. The cable will not have any slack and will have some preload on it when properly adjusted.
30.) Re-install the H pipe and remaining items.
31.) When you have visually checked all the bolts, fittings and other parts are present and not interfering with each other, then take the car down off the jack stands.
32.) Be prepared to put the car back up on the jack stands to adjust the clutch and tighten up any loose items found after the test drive…
If you have a T5, you may be able to remove the trans & re-install it if you can bench press the 75 lbs that it weighs. If 75 lbs is too heavy, don't hurt yourself, get a trans jack. If your car has a Tremec 3550 or TKO, you will need a helper or trans jack because it weighs 100 + lbs. I built a trans jack from 2x2 angle iron, some swivel casters, 2x4's, 2x6's and a cheap floor jack. PM me if you are interested & I will send you the photos (8 MB) with the write up.
While you are at it, replace the stock cable & quadrant if it is still present. My choice for clutch & quadrant for street use:
Ford Racing M-7560-A302N - Ford Racing Clutch Kits - Overview - SummitRacing.com Ford Racing M-7560-A302N king cobra clutch kit $215-$245
Ford Racing M-6375-B302 - Ford Racing Flywheels - Overview - SummitRacing.com flywheel, cast iron $92
The quadrant needs to be replaced if you use any type of aftermarket cable or adjuster. My preference is a Ford Racing quadrant, adjustable cable and Steeda firewall adjuster. The adjustable Ford Racing cable is just a good as the stock OEM cable. It allows a greater range of adjustment than a stock cable with a aftermarket quadrant and firewall adjuster. Combined with the Steeda adjuster, it lets you set the initial cable preload and then fine tune the clutch engagement point to your liking without getting under the car.
Using a stock OEM cable and a single hook quadrant may result in not having any free pedal travel before the clutch starts to disengage. I found this out the hard way.
See Summit Racing - High Performance Car and Truck Parts l 800-230-3030 for the following parts.
Ford Racing M-7553-B302 - Ford Racing V-8 Mustang Adjustable Clutch Linkage Kits - Overview - SummitRacing.com Cable and quadrant assembly $90
Steeda Autosports 555-7021 - Steeda Autosports Firewall Cable Adjusters - Overview - SummitRacing.com Steeda firewall adjuster. $40
You asked about a tutorial on the rear main and basically it's the same as replacing the clutch, just another step is all.
This should give you all the information you'll need to replace your rear main.
CarTech, Inc.: Browsing Fox-Body Mustang Clutch Install
Basic tools:
12mm 12 point for the D/S bolts
12mm and 13mm for the cross member
16 mm (or 5/8) for the trans mount and bellhousing bolts
15mm swivel for the trans bolts
11mm for the speedo cable
13mm for the starter bolts, pressure plate bolts.
Torque Specs from the Ford Mustang Shop Manual
Wow this is great! Just what I was looking for. What do I have to do to reface the flywheel? I am not sure of that step. How long has this taken you guys? I can use a lift, but I am worried I'll get stuck and be rushed later on. I only have weekends and that is about it. If I could do this in my garage on stands, that would be best. When we pulled the engines and trans on austin healys, we pulled them as a unit with a come along, I don't ever remember doing anything with a flywheel
Again, thanks so much, I will keep you posted.
Doc
Refacing the flywheel is a macine shop job that returns the flywheel friction surface to the same specs as a new flywheel. It is done on a Blanchard grinder, so not every machine shop has the tools to do it.
See Blanchard grinder - Google Search to learn more about the Blanchard grinding process.
Time to remove & reinstall is 6-8 hours the first time it is done. The typical problem points are the exhaust header to H pipe bolts that can be very difficult to get loose. PB blaster is almost a must have for this part of the job. Get some stainless steel nuts from Home Depot and Never-Seeze anti seize compound from NAPA. Apply generous amounts of Never-Seeze to to the exhaust system nuts and studs and will save you time and trouble next time you have some work to do in that area.
Doc
I've replace my rear main 2 different times and I've always done it in my garage with jack stand at he front and rear so I have room enough to lay on my back remove parts and and pull the transmission.
As stated above figure 6-8 hours and you should be safe.
Thanks for all the info and help guys. I am going to start and put the tools together, will probably set aside a weekend within the next three weeks. I might get the car up on two jack stands tomorrow and start to take a look, buy or borrow the stands I will need. It doesn not sound like the two I have will be tall enough. Is there a trick to putting pictures on this site? We could not get our others to load. Which seal do you think I will have the best results from?
again, thanks for all your input, I will keep you posted!
Doc
