can you re-use head bolts?
i have reused head bolts in the past. one thing i have found is that they tend to stretch over time, and while they can be reused once or twice, but after that i recommend they be replaced. and yes arp is happy because they sell the best replacement bolts on the market today.
On certain engines (mostly late model) they use a "torque to yield" tightening plan. Basically, bolts stretch as they are torqued down and this creates a clamp load. After the bolts are taken off they should return to their original length, but in a "torque to yield" plan they stretch the bolt until it becomes "plastic" and doesn't return to its original length. When the bolt is stretched to this state it is no longer reusable. Any bolt can become a "torque to yield" bolt if it is over torqued. For the $50-60 bucks I'd replace them to be safe.
The pre-'80s bolts are just normal Grade 8 fasteners AFAIK. They should be good for a couple uses. I went with ARPs after some "grade 8" bolts from Performance Automotive Warehouse actually stretched and broke at ~60 ft/lbs right out of the package. Wasted a pair of headgaskets in the process. :mad: I guess it's good that they broke otherwise I would have run the engine and been pulling heads in the car rather than on an engine stand.
I took the heads off and sent them in for porting. Can I re-use the head bolts when I re-install the heads?
If this is the first time the heads were off the motor you can re-use (as they were torqued at the factory), just be careful not to over torque when you re-apply.
If you are not sure about how many times they have been used then invest in another set and when installed after each use simply make sure they are not over torqued. I would also suggest upgrading to studs if you purchase a new set.
HistoricMustang
www.historicmustang.com
ARP has done some interesting studies. Apparently with quality fasteners like ARP bolts and some others you are actually SUPPOSE TO reuse them but the trick is making sure they go into the same hole every time. Apparently the threads will wear into each other. At least thats what ARP has said. I imagine you can old torque them down so many times before they eventually stretch too much.
As long as they are not torque to yield I would say you could provably use them about 3 times total with no worries. As for me, I'm going to get studs for the head.
What if you jacked one side of the engine up ?
That might of worked. You'd have to do it twice (once on both sides) but if I remember correctly you'd have to get like a 30 degree twist to get the head to slide out. Plus you have to remove the export brace. Either way it's not pretty.
Also, Jerry has a 69 I believe so he has more room in the engine bay.
That is also correct.
