Cannot Decide
  • Thread starter Thread starter DH71986
  • Start date Start date Feb 17, 2017
  • 3
  • 6
1 of 6 Next Last
D
DH71986
64
11
18
Feb 17, 2017
  • Feb 17, 2017
I cannot decide what to do! I have located a 351w for very little money but I also would like to go turbo on my 95 GT. I am not looking for something that is a monster 6 million thousand horsepower, I would be happy with around 4-450 and still be very happy on the street because is is my daily driver. The 351w I know as of right now it will need freshing up(bearings, rings, etc) but not sure if it will need machining. Maybe stroker? Now going turbo I know a lot of the drivability is in the tune and the longevity as well. I am also on a very strict budget per wife and 2 kids. Which of these would be the most economial as this very moment. Any opinions from anyone with experience with one or both situations would be greatly appreciated. Thank you.
RaggedGT
Mod Dude
Jul 20, 2014
4,762
3,220
203
Taylorsville ky
Feb 18, 2017
  • Feb 18, 2017
I think I'd start with the 351.
I'd blow it apart and take it to the machine shop and have them check it out,and go from there recomendations..
A warmed up 351 with a good cam,heads and intake would be night and day different compared to the stock 5.0. Once it's up and running you could take time to map out a turbo setup and all the supporting mods-tune etc
Reactions: A5literMan and elarm1
mustangman14
22
  • Feb 18, 2017
if efi it could be expnsive but carbed you could get the edelbrock top end kit with a rebuilt bottom end and you would have 450 horses with no poer adder
D
DH71986
64
11
18
Feb 20, 2017
  • Feb 20, 2017
Thank you for our input. Who has the best deal on a decent set of 351w heads and intake? I have searched a great deal online and for a few but now sure if they are worth it. (302 parts make 302 power) I found these:
https://lmr.com/item/SVE-6049A-K/SVE-Mustang-Performance-Aluminum-Cylinder-Heads-79-95
But I am afraid they will not be enough for a 351w. The main other question I cannot find an answer to is will it fit under my stock hood or does this car use the same mounts as everything else?( didn't know if the conv. mounts were different).
mustangman14
22
  • Feb 21, 2017
same mounts as 5.0. there are dropped solid motor mounts but for best ride bolt on cowol hood. as for engine issue those heads will not support huge numbers on hp but will make great torque . with what you want to do i wuould go this route cobra or lightning heads, cobra or other direct fit rockers 1.7, lightning lower and cobra upper. it will recreate the cobra r engine and install an on3 turbo and you will make nice hp
D
DH71986
64
11
18
Feb 21, 2017
  • Feb 21, 2017
So what you are saying is using a gt40 top end? I thought about that but would that be enough flow or would that choke the 351? Would a TFS stage one cam be ok? Piston to valve clearance? Or would having a custom cam ground be the way to go? Sorry for all the questions I have read so many forums now I cannot keep them straight!!!!
Dan_Soprano
7,410
54
129
Jacksonville, FL
Feb 21, 2017
  • Feb 21, 2017
I would stay away from those SVE heads. You can usually find good deals on a good set of used AFR 185's or Trick Flow equivalent for that price. Add a mild street cam to that on a stock 351 and you will have all the power you need for a daily driven street stang.
mustangman14
22
  • Feb 21, 2017
if you are runnin. efi you would need a cam with at least a 115 degree lsa. that way you can use the stock computer. your best bet would be a custom cam with an emphasis on exhaust. you can use a aftermarket intake but a gt40 intake would sit lower and if you port it it could flow better. also it will accept a 70 mm throttle body
D
DH71986
64
11
18
Feb 22, 2017
  • Feb 22, 2017
Here is what I am thinking and ya'll can tell me if I am wasting my time. My thought was to just have the stock heads worked over(port polish valves etc). Would that be just as well as a gt40 type head?
Would I be saving any more money doing it this way?
mustangman14
22
#10
  • Feb 22, 2017
  • #10
trickflow springs and 1.7 pedestal rockers with a small cam, steeda #19 will give you drivability with your stock computer and around 520 lift and really good with a turbo
D
DH71986
64
11
18
Feb 23, 2017
#11
  • Feb 23, 2017
  • #11
One other question I have is will a tko transmission directly replace the t5 I currently have or will I need to buy a whole kit? I know the t5 wont live behind the 351 very long but hope it will last long enough for me to save for a tko.
mustangman14
22
#12
  • Feb 23, 2017
  • #12
bell housings are different and depending on which model (one tko500 has 10 spline input) a new clutch, fork and driveshaft. you can sell the tko and have astro performance or g force build yours. they can build you one to work with your rear en gears and engine torque rating
Dan_Soprano
7,410
54
129
Jacksonville, FL
Feb 24, 2017
#13
  • Feb 24, 2017
  • #13
The bell housings for a SBF windsor are not different. 302 / 351 are both the same.
mustangman14
22
#14
  • Feb 24, 2017
  • #14
tko transmissions have a different size hole in the bell housing also the tko transmissions have a shorter fox body length input shaft and overall length
D
DH71986
64
11
18
Mar 2, 2017
#15
  • Mar 2, 2017
  • #15
Which flywheel would you use? Will the stock 351 flywheel work? Also would these headers work in a '95?
https://lmr.com/item/BBK-1511/79-93-Mustang-BBK-351-Swap-Chrome-Shorty-Headers
Or should I just save more money and put a turbo on it?
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 2, 2017
#16
  • Mar 2, 2017
  • #16
Stock 351 flywheel will be fine. I'm running the BBK 1 3/4 351w swap longtubes and they work fine in my 95. Only thing I had to do was lightly "massage" the #5 primary tube for steering shaft clearance. I'm personally not a fan of turbos, so my vote is the 9.5 deck!
D
DH71986
64
11
18
Mar 2, 2017
#17
  • Mar 2, 2017
  • #17
That is good to know that I can use the stock flywheel. I am still waiting on my motor. The gentleman I am getting it from still has to pull it out. He is a very busy guy to say the least. I don't think he will let me help him. I would think I should have it in a week or 2. I am not in hurry anyway. I will try and get some pictures or it and my car if I can figure out how to do that.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 2, 2017
#18
  • Mar 2, 2017
  • #18
If you need any advise about dropping a 351 based engine in I got you. I'm in the end stages of finishing up my 408w build.
D
DH71986
64
11
18
Mar 3, 2017
#19
  • Mar 3, 2017
  • #19
I am going to need all the help I can get. This will be my first engine swap so I hope I picked a fairly simple one. It will also be the first engine I have rebuilt by my self. I will take my time and make sure everything is put together correct and torqued correctly. This car is my daily driver and it has to be reliable. I guess we will see.
D
DH71986
64
11
18
Mar 6, 2017
#20
  • Mar 6, 2017
  • #20
I received my engine today. I am pretty excited about starting this project! I have to find an engine stand and a cherry picker to get this thing home. I will get pictures as soon as I can figure out how to upload them.
  • 3
  • 6
1 of 6 Next Last
G
Fox engine swaps
  • Gravity
  • Aug 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 12, 2025
2000xp8
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
