Can't decide:short block
  • Thread starter Thread starter ras50gt
  • Start date Start date Jul 25, 2009
Help me decide
  • 331 short block
    Votes: 4 28.6%
  • 351/393w short block
    Votes: 10 71.4%
  • Total voters
    14
ras50gt
200
  • Jul 25, 2009
I want to start an engine build as a winter project. I thought I made up my mind to go with a 331 but thinking more and more about going the 351/393w route.
I know there are a ton of threads on 331/347 vs 351w, and I have read a lot of them. But, wanted to throw up a quick poll
Which would you go with and if you have time,explain why?
Things to keep in mind: This will be a street car, must be reliable as I would like to keep it as close to a daily driver as possible(not many miles a day). Looking to keep comp low as I already have a paxton sl sitting in my garage waiting to be installed. I would like a trick flow street top end kit, but may just put together a h/c/i combo. Want to make at least 350 hp, hopefully closer to 400 hp. Cant afford a dart block,etc. Also, bugdet in mind as I dont have a lot of money. Will buy parts in steps to finish it up.
Only mods on the car now are bbk shortys,magna x pipe/cats. Then of course the paxton sl still in the box. Like to know if anyone has put a 302 supercharger kit onto a 351w also?
ras50gt
200
  • Jul 27, 2009
TTT
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Jul 27, 2009
  • Jul 27, 2009
Big inch small block, carbed. /thread.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 27, 2009
  • Jul 27, 2009
351... more tq and power and shouldn't be an issue getting one in with all the swap parts they have available.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 27, 2009
  • Jul 27, 2009
Out of the above options: 351/393, EFI. Carbs are old tech, for a reason.
A 302 SC kit should fit a 351W based engine, but I almost wonder if it would have any clearance issues with the passenger side frame rail? Mine is awfully close with the 302.
mustangman9812
661
Mars Hill, NC
Jul 27, 2009
  • Jul 27, 2009
351/393w
R
Rookie71
28
  • Jul 27, 2009
Kinda depends on what your future plans are. Seems the cheapest route would be the 331 w/ SC. You can still run decent compression and have it drive almost like stock unless you are in the boost. Now if you start getting bored and want to significantly increase hp later on, the stock blocked 331 won't hold near as much as a stock blocked 393W.
Guilty93
marietta ga
Jul 30, 2009
  • Jul 30, 2009
no replacement for stroke! and blarg @ efi carbs are usaly good for a little more power from what ive seen and if you spray you will get a much better result plate for plate. of course im biased im building an aluminum 427 stroker for my notch HAHAHA (very slowly as in i have only the $3000 block)
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 5:48 PM
from6to8
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
