can't decide what my fuel set up should be!?!?!!
i have a 97 GT (55K miles) convertible with accufab 75mm plenum/tb, AFM power pipe, pullies/ timing adj., header back O/R exhaust....will be getting the pro-m MAF.
i don't know what size injectors to go with. need to figure out what size for this N/A setup as a DD and POSSIBLY a sprayed strip car. along with the injectors (when someone helps me figure out which ones i should go with) i will be getting new rails, pump(s), and probly the plasma booster.
thanks for any help,
Gus
I think the stock 19# or 24# would be OK. How big a shot are you gonna spray? If you sprayed a 75 shot I think the 19#s would be OK, but if you spray any more get some 24#. If it was my car I would get it tuned to be on the safe side. Your tuner will be able to tell you more about what you need than we can.
